Key Sticking in the Ignition
I Have 97 accord and my key from time to time gets stuck in the ignition. ive never had this problem before, is this problem repairable or would i have to replace something?
If you should notice that the shift position display in the cluster fails to illuminate the "P" while the Shift lever is in "Park", the problem lies with the quadrant switch in the console.
This item not only tells the TCM what gear's been selected, but also energizes the key interlock in the steering column (so that you can't lock the steering wheel while still in gear).
When it doesn't make the connection in the "P" position, it won't release the key, nor turn on the indicator in the cluster.
P
P
lol, your key sticks in ignition....i can pull my key out while the car is running.
i however, like being able to start my car, take my key and lock my doors while it warms up
