Please Tell me this would need a new clutch...
Old Jan 6, 2006 | 08:22 AM
Justin99Accord's Avatar
Default Please Tell me this would need a new clutch...
When I start my car and put it in gear (Sometimes force it) I hear a wierd noise, but when Its not in gear, the noise stops, I have no problems accelerating but, I cant downshift unless I completly stop my car, otherwise it wont go into gear (Like if im on a freeway). I only hear the noise when im in gear and im idle. When I step on the gas, I can't hear it anymore, maybe thats just because my exaust is to loud. So would that be the clutch? Tranny? or ??? Appreciate all help, thanks .
Old Jan 6, 2006 | 08:23 AM
Default Re: Please Tell me this would need a new clutch... (Justin99Accord)
a little background as well, the car has 164,000 miles on it, and is a 99 Accord, still running on the same clutch that was in there when my mom bought it.
Old Jan 6, 2006 | 08:29 AM
twobit's Avatar
6th gen accords have horrible transmissions, if your going to rebuild it or get a remanufactured one it'd be upwards of 3-4k. In that case what I am considering doing since I have a 6th gen myself is swapping a JDM h22a engine(200hp) that has everything when and if I possibly will purchase it. All for $1990. Quite a deal rather than rebuilding or getting a whole new transmission huh? Yeah sure the swap will be a couple$$ or I might possibly get my friend to help me out but heck, 200hp rather than 150 not to mention you have the possible guarantee that your tranny won't get crapped up again since 6th gen trannys go so much. PS Mines going at 111k miles comparitable to my brothers old 4th gen which went 220k and had his tranny that pretty much got demolished.
Old Jan 6, 2006 | 08:32 AM
Default Re: Please Tell me this would need a new clutch... (twobit)
what? I never said anything about me rebuilding my tranny.
I've had one person say it may be the tranny, all the others say its something to do with the clutch. I'm praying its not the tranny.
Old Jan 6, 2006 | 08:35 AM
YeuEmMaiMai's Avatar
the manual trannies are fine and since he is talking about clutches, I am guessing he has a stick.
IF your auto tranny needs a clutch pack replacement, make sure that they do the 2nd gear fix as part of the rebuild otherwise you are gonna be right back in there with the same failure
Old Jan 6, 2006 | 08:36 AM
you said you have to force it into gear? That sounds like a syncro problem to me........
Old Jan 6, 2006 | 09:18 AM
P_Adams's Avatar
If you have problems shifting in and out of ALL gear ranges, you most likely have an issue with the Clutch, or the clutch release mechanism.
If your shifting issue is with only one (or two) gear ranges, you most likely have Gear / Syncro ring / shift fork issues
P
Old Jan 6, 2006 | 11:45 PM
Default Re: Please Tell me this would need a new clutch... (P_Adams)
its all gears, and I cant downshift once I shift upwards, unless I am completly stopped, then sometimes it lets me.
Old Jan 7, 2006 | 12:07 AM
The Phil's Avatar
Dragging clutch probably. Check clutch fluid and bleed if necessary.
Old Jan 8, 2006 | 07:35 AM
Default Re: Please Tell me this would need a new clutch... (The Phil)
I have a stick, and the clutch was going bad anyway, its a 99 with 160k miles on the clutch, im going tomorrow, to get a new one installed.
Appreciate the help.
Old Jan 8, 2006 | 08:04 AM
P_Adams's Avatar
Glad we could confirm what you suspected anyway. You were correct to ask a second, and a third, a forth, and a fifth opinion.
P
Old Jan 8, 2006 | 08:06 PM
I like to be sure , Sorry if I wasted 3 minutes of your reading pleasure
Old Jan 8, 2006 | 08:12 PM
accordselux's Avatar
Me Gusta History
Its not your fault someone doesnt take the time to read and starts writing about an auto tranny...i've got a 6th gen auto and i'm on my 2nd tranny and 300 bucks worth of warrantied repairs on that baby...be lucky all you need is a new clutch
Old Jan 8, 2006 | 10:52 PM
Default Re: Please Tell me this would need a new clutch... (accordselux)
I am lucky!
renzis00
Oct 12, 2012 08:06 PM
Civicvtihatch
Oct 9, 2005 12:39 PM
totsie7944
Mar 26, 2005 05:40 PM
