what i can/can't do ?
Old Jan 5, 2006 | 11:35 PM
Zing Xiong's Avatar
Default what i can/can't do ?
i've looked for specs but *** up short .. what i need to know is Can i swap out some internal pieces on a 94 sohc vtec motor to a 88 dual point motor..?? if i can what are those pieces (example: pistons, valves, rods etc. )
Old Jan 5, 2006 | 11:40 PM
31flavorscivic's Avatar
Default Re: what i can/can't do ? (Zing Xiong)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zing Xiong &raquo;</TD></TR><TR><TD CLASS="quote">i've looked for specs but *** up short .. what i need to know is Can i swap out some internal pieces on a 94 sohc vtec motor to a 88 dual point motor..?? if i can what are those pieces (example: pistons, valves, rods etc. ) </TD></TR></TABLE>
LOLOLOL
Old Jan 6, 2006 | 09:51 PM
Zing Xiong's Avatar
Default Re: what i can/can't do ? (31flavorscivic)
lol your much help .. NOT
Old Jan 6, 2006 | 10:36 PM
1993civicex's Avatar
i belive pistons will fit if u take the crank also...... take the entire vtec head dont expletive with the valves and ****........that way u have mpfi and vtec.......................lol its a d16z6 ur talking about rephrase ur question
Old Jan 6, 2006 | 11:15 PM
crxnj's Avatar
Default Re: what i can/can't do ? (1993civicex)
Im assuming we're talking about a 1.6 sohc vtec..(D16z6)
The 1.6 crank has bigger journals then the 1.5
The 1.6 rods are longer then the 1.5 rods..
The pistons will work (Both are 75mm)
The whole entire head bolts up to the 1.5 block (A.K.A. Mini-me)
Old Jan 6, 2006 | 11:21 PM
Zing Xiong's Avatar
well just rebiulding the d15 and i have a d16 laying around from the last swap that i did .. just don't want to mess with all the wires rite now .. plus the previous owner said the d16 was knocking ,never had the chance to try out the motor, i b16 the coupe rite away. plus it's freaking cold up here in minnesootah i'll wait til spring , summer for all that ..
Old Jan 6, 2006 | 11:30 PM
Zing Xiong's Avatar
Default Re: what i can/can't do ? (Mr.speaker)
i went to zealautowerks d-series calculator plugged in some info and the back ground turned red does that mean NO CAN DO..
http://www.zealautowerks.com/dseries.html
if i shove the d16 rods in the d15 w/d16 pistons will the pistons hit the head..??
Thanks for your response...
Old Jan 6, 2006 | 11:32 PM
crxnj's Avatar
I told you already the 1.6 rods are longer..134mm compared to 137mm..
Also The d15b1/2 has a shorter deck height then the d16z6..
Old Jan 8, 2006 | 10:24 PM
Zing Xiong's Avatar
thanks for all your response ..
maybe i'll find other alternatives
great info shanks
Old Jan 8, 2006 | 10:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zing Xiong &raquo;</TD></TR><TR><TD CLASS="quote">lol your much help .. NOT</TD></TR></TABLE>
I would like to fully apologize for my conduct last night, it will never happen again .
pendejon
Mar 27, 2006 02:41 PM
westcoastcat
Oct 23, 2003 09:24 PM
broncoman74
Jul 27, 2003 12:15 PM
92civicJDM
Aug 31, 2002 08:36 PM
