changing stock rear brake pads on 5th gen
Old Jan 5, 2006 | 07:09 PM
bigj505's Avatar
Default changing stock rear brake pads on 5th gen
i really do not feel like paying someone to change my rear brake pads. is it possible to get a quick write up on how to do it and what tools i might need?
Old Jan 5, 2006 | 07:15 PM
mgags7's Avatar
deliii.com has a helms manual for your car in pdf
read it
Old Jan 5, 2006 | 07:27 PM
bigj505's Avatar
Default Re: (mgags7)
u da man thanks
Old Jan 5, 2006 | 07:36 PM
lude98SH's Avatar
Default Re: changing stock rear brake pads on 5th gen (bigj505)
1. Remove wheel
2. Remove caliper and old pads
3. Compress caliper ( They screw in, unlike the front which u can use a c-clamp for)(I used a caliper tool kit for mine)
4. Clean rotor and use some sand paper to rough up rotor to ensure the pad breaks in correctly to the rotor
5. I sprayed my pads with Brake disc quiet (optional)
6. Place new pads onto rotor ( make sure the little medal dot on the pad lines up with the crosshair on the caliper piston)
7. Put caliper back on a tighten to spec
8. Put wheel back on and tighten until snug (star pattern)
9. Lower car and tighten lugs to spec (star pattern)
10. **Get into car and pump brakes before you move the car at all
11. Take car out and break in your new brakes ( it should say on the box the proper way to break in your new pads)
Old Jan 5, 2006 | 07:41 PM
bigj505's Avatar
Default Re: changing stock rear brake pads on 5th gen (lude98SH)
even better. thanks alot guys
Old Jan 5, 2006 | 07:55 PM
lude98SH's Avatar
No problem.
lowered94accord
Dec 2, 2013 01:59 PM
Rammy
Apr 16, 2009 11:46 AM
E-brake or Handbrake
54
Oct 11, 2004 03:02 PM
Mike813
Sep 14, 2003 12:46 PM
zk11
May 17, 2003 04:42 AM
