Do piston size make more compression
I build'n a d16, but I'm stuck wondering if .40 over pistons are a better choice for my N/A build up. I was just going to go with .20over but If I get .40over or maybe even .50over would it make a diffrence?????
Thanks
Please help
Thanks
Please help
Actually changing the bore size does have an affect on the compression ratio..You have to remember the the combustion chamber in all of this..Enlargening the bore but leaving the combustion chamber stock size if going to have some kind of affect on the compression ratio..Not noticeable though, but there..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mer2ski »</TD></TR><TR><TD CLASS="quote">will i make more power with the larger pistons???
Is it a good Idea to increase the size?
Yeah because increasing the bore makes the displacement bigger,,So you get get more tq..Either way you should over bore the engine when rebuilding it..That's what I was taught aynway as it gives a true circle ..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mer2ski »</TD></TR><TR><TD CLASS="quote">bottom line is to over bore??? .40 over is better???</TD></TR></TABLE>
good luck boring .40
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 »</TD></TR><TR><TD CLASS="quote">
Yeah, I think he forgot a zero.. I hope
b00stedbyFastrax
Jun 27, 2005 09:20 AM
Justin Olson
Feb 24, 2004 07:09 PM
