timing belt
i doubt you are going to compress the cylinders. if you can good luck and let me know how. if you are trying to set time then that's a different story. to get the timing belt back on, you will have to release the tension on the tensioner, install belt, retesion the tensioner.
buy a manual, it will explain the process better than i did.
good luck.
good luck.
My teacher said when we do mine in class next week, we're going to tie up the gears so when we remove the cams, the gears stay in place and the belt doesn't move so we don't risk having any timing issues
