which ecu code list should I go by?
Old Mar 19, 2002 | 06:23 PM
neumonik's Avatar
Default which ecu code list should I go by?
I've just finished puting a b18c5 in my civic with a hondata stage 3 obd1 conversion (p28 ecu).
I threw a code 1 the other day and looked in both my helm's manuals. If I go by the one for the integra it says bad ecu (car runs perfect), if I go by the civic book that says code 1 == bad o2 sensor. Any rate... I reset the ecu and the code went away (for now).
Am I correct when refering to the civic helm's since the p28 is from a civic... right?
Any direction???
Old Mar 19, 2002 | 08:06 PM
boomslang's Avatar
Default Re: which ecu code list should I go by? (neumonik)
Use the P28 codes.
Old Mar 20, 2002 | 03:26 AM
misledyouth's Avatar
New User
Default Re: which ecu code list should I go by? (Inlinefour)
bad ecu should be a code zero or a constant light when you go to check the codes i am not sure which one. But a code one is a bad o2.
Jesse
Old Mar 20, 2002 | 04:17 AM
neumonik's Avatar
awesome! Thanks....
Geis
Dec 17, 2015 11:20 AM
IIXtremeHansen
Dec 19, 2007 06:04 AM
95CivicGSR707
Apr 15, 2007 09:39 PM
valentino2k3
Oct 9, 2004 02:47 PM
4drGSR
Feb 23, 2002 07:40 PM
