Hey guyz, Turbo question.
Old Jan 5, 2006 | 04:29 PM
JaHnAbOi's Avatar
Default Hey guyz, Turbo question.
Hey guys, I'm new to the whole turbo/forced induction scene and I was wondering what mani I need to use for my d16a6 block which is going to be housed with a 14g turbo (Off of starion). Is there any mani's that I can use without making a custom one that anyone is aware of? Something I can plug and play with? I'll post pictures of my turbo below (junkyard turbo that is! lol)
If any info is provided, I would be most appreciative of the advice! Thankyou guys in advance.
Old Jan 5, 2006 | 05:16 PM
NACvicSi's Avatar
I thought starion turbos suck and ran out of breath quickly? Might be able to just get an adapter plate and use a HF/STD manifold.
Old Jan 5, 2006 | 06:59 PM
Mach69's Avatar
Default Re: (NACvicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NACvicSi &raquo;</TD></TR><TR><TD CLASS="quote">get an adapter plate and use a HF/STD manifold.</TD></TR></TABLE>
That works well for a low budget turbo setup. Which is something I plan on doing.
ALSO, get a 1g dsm bov. I hope you got the (2.2L?) starion fmic too.
Old Jan 5, 2006 | 07:37 PM
beyondspexj's Avatar
talk to wierracing about making you an adapter plate if you use the hf/std manifold. the adapter plate i have is really good quality.
Old Jan 5, 2006 | 08:27 PM
crxnj's Avatar
Yeah man get an hf manifold with an adapter plate..Maybe do some porting with a dremel also
And the 14g turbo is pretty good,flows more then the 14b turbo..It might suck for dohc vtec motors but for a d16a6 it would be perfect..14g has been proven to make more then 325hp..
Old Jan 5, 2006 | 10:26 PM
JaHnAbOi's Avatar
Default Re: (Mr.speaker)
Wow I feel the love of honda-tech. So hf mani with adapter plate it is. Anyone know where I can grab an hf mani?
Mach69, if you don't mind me asking, how much would it cost for the plate? Oh, and how much do the mani's go for? Sorry for such noobish questions guys.
Specs on 14g turbo... When I found the turbo at the junkyard it was from a fresh starion. The owner previously had the turbo rebuilt with 16g blades put in it. I had a couple of starion owners look at it for verification. So hopefully it runs as good as it looks.
As for the intercooler, I was able to grab a starion fmic, but I was able to grab a 3inch thick side/top mount 95 Turbo Thunderbird intercooler. =P I'll take pictures of it. It isn't long, but its thick. And its black! The sleeper look. It was exactly what I was looking for. Hopefully that intercooler will be okay. Any input on this?
As for my emissions, what ems/ecu would be advised for my turbo maps/tuning? Thanks guys once again.
Old Jan 5, 2006 | 10:37 PM
SoClose's Avatar
Default Re: Hey guyz, Turbo question. (JaHnAbOi)
pretty clean for a turbo off of a old dsm starion . .
Old Jan 6, 2006 | 08:44 AM
blackhbkid's Avatar
use a hf mani and get an adapter plate then for your turbo if your looking to save some money just get a t25 just make sure it dosnt have any shaft play you could most likly trade your turbo for a t25 and get some money on top use dsm 450cc injectors as for the charge pipes you can buy the bends and go to your local exhaust shop and they will help you out for cheaper set ups use a internal wastegate use hondata for your tuning it works good and is cheap there is a guy here running close to the same setup and he is running a p28 tuned with hondata you can also pick up a dsm bov for like 10-15 bucks
Old Jan 6, 2006 | 02:07 PM
JaHnAbOi's Avatar
Default Re: (blackhbkid)
Wow... all info in one simple statement. Couldn't have asked for anything more. Haha. Thanks.
Old Jan 6, 2006 | 07:25 PM
Mach69's Avatar
Default Re: (JaHnAbOi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi &raquo;</TD></TR><TR><TD CLASS="quote">Mach69, if you don't mind me asking, how much would it cost for the plate? Oh, and how much do the mani's go for? Sorry for such noobish questions guys. </TD></TR></TABLE>
You can probably find the hf manifold at a junkyard for 15-25 bux is all that should cost. As far as the adapter, I would expect 70-100 bux for one.
Old Jan 6, 2006 | 07:34 PM
NACvicSi's Avatar
Default Re: (Mach69)
Adpater plate from wierracing will be about $50
aaronweir@cogeco.ca
Old Jan 6, 2006 | 10:31 PM
AJxr's Avatar
learn some more from http://www.homemadeturbo.com DIY stuff is great although some disagree.
Old Jan 7, 2006 | 01:30 PM
JaHnAbOi's Avatar
50 dollars? That's pretty damn good. As for the hf/std mani's. Which one is better? And what is the difference between the two? What cars have these manifolds?
Old Jan 7, 2006 | 02:29 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi &raquo;</TD></TR><TR><TD CLASS="quote">50 dollars? That's pretty damn good. As for the hf/std mani's. Which one is better? And what is the difference between the two? What cars have these manifolds? </TD></TR></TABLE>
they are the same. they come from the civic STD and the CRX HF (go figure) i have a VX manifold, dont know if its the same but it uses a pre-downpipe cat like the HF did so, i dont know
Old Jan 7, 2006 | 02:34 PM
jedubz's Avatar
Default Re: (beyondspecs_jamar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaHnAbOi &raquo;</TD></TR><TR><TD CLASS="quote">Wow I feel the love of honda-tech. </TD></TR></TABLE>
If you think this is good help, try the love of homemadeturbo.com They can tell you just about anything you need to know about HF manifold set ups, and starion turbos
Old Jan 7, 2006 | 05:30 PM
JaHnAbOi's Avatar
Default Re: (jedubz)
Will do, will do. THanks everyone for the help. I appreciate it! Due to your knowledge I learn!
Old Jan 15, 2006 | 05:09 PM
blackhbkid's Avatar
hey are you still looking for an adapter plate if so go here http://www.bmcrace.com/products/adapters/
Old Jan 17, 2006 | 11:49 AM
JaHnAbOi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackhbkid &raquo;</TD></TR><TR><TD CLASS="quote">hey are you still looking for an adapter plate if so go here http://www.bmcrace.com/products/adapters/</TD></TR></TABLE>
Those bmc adapter plates look good! Thanks for lookin out. I'm thinking of selling my turbo to a friend and buy a garret t3 standard. Bigger turbo, and the adapter plate is only 45 dollars!
Anyways, question about the charge pipes/intake pipes. Does anyone know a not so costly place to purchase pipes (u bends/ 45 degree angled bends/ etc) for cheap? [So I can customize.]
Thanks guyz once again!
Old Jan 17, 2006 | 02:46 PM
4thgenhtch's Avatar
Summit racing, for mandral u bends, The you can just cut em up
Old Jan 17, 2006 | 08:14 PM
blackhbkid's Avatar
Default Re: (4thgenhtch)
at homemadeturbo there was a guy that found old aftermarket intakes in a dumpster and then got the rest of the pipes he needed at home depot
Old Jan 29, 2006 | 07:58 PM
thrty8street's Avatar
good luck with the project
Old Jan 29, 2006 | 09:53 PM
currently selling my hf manifold and adapter plate.. sent ya a pm
seeareex
Mar 22, 2008 12:51 PM
turbodan4
Sep 11, 2004 10:43 AM
project142
Dec 22, 2003 04:13 PM
RCSIVTEC
Jun 9, 2002 07:42 PM
