No Spark
If you get no spark as stated......
first off make sure t-belt is not broken,,,,,,,,,remove oil filler cap. have someone crank the engine and make sure rocker arms are moving,, if they are not you got a broken t-belt,,,,,,,,,,if they move , it could be a bad ignitor, coil, rotor,
I'm assuming from the header of your post that you actually verified that you have no spark. Turn the ignition on and listen for the fuel pump to cycle. If you hear it then you probably have a bad ignitor. If you don't hear it you have a bad main relay or if you didn't actually check to see if you had spark, it could be the relay or the fuel pump. I'd put my money on the ignitor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amckee »</TD></TR><TR><TD CLASS="quote">I'm assuming from the header of your post that you actually verified that you have no spark. Turn the ignition on and listen for the fuel pump to cycle. If you hear it then you probably have a bad ignitor. If you don't hear it you have a bad main relay or if you didn't actually check to see if you had spark, it could be the relay or the fuel pump. I'd put my money on the ignitor. </TD></TR></TABLE>
Yo amckee........ what happens if it has a broken t-belt ??? or a bad coil ??? it still will get no spark and the fuel pump will prime when you turn the key on,,,,,,,
Diagnose, Diagnose, Diagnose........ before you replace parts. never assume it is this or that ,untill you properly diagnose it.....
You already told him to check for a broken timing belt. Why do I need to repeat that in my post? If he has voltage at the yellow and black wires going to the ignitor and still has no spark the ignitor is bad.
Jdm=Ep3
Aug 4, 2018 02:34 PM
junkyard racer
Jul 15, 2006 07:21 AM
1 speedstar
11
Aug 23, 2004 01:08 PM
