running without vtec
Old Jan 5, 2006 | 03:54 PM
kkitzman's Avatar
Default running without vtec
im currently swapping out my old cx motor from my 1993 civic with a d15b vtec, i have the p28 ecu but i still have the cx stock wire harness and with that connected the vtec wont run if im right, with the motor not running vtec will that damage it in anyway? and how do you manually wire the vtec up with the cx wire harness?
Old Jan 5, 2006 | 04:05 PM
EG93si's Avatar
Default Re: running without vtec (kkitzman)
i dont think i would hurt it, anything its prob better for it. you need to run wires for your vtec, its like for the solinoid (sp) and the pressure switch, if you search it, youll find it, promise, its been cover alot.
search is your friend
Old Jan 5, 2006 | 05:31 PM
EGDC2CIVIC's Avatar
Default Re: running without vtec (EG93si)
https://honda-tech.com/zerothread?id=1171263
about half way down the page you will find your answer
xJDMCx
20
May 1, 2011 08:57 AM
alex22
11
Mar 18, 2010 07:09 PM
rollintegra
Dec 10, 2008 10:55 AM
madvtakkk
Jan 7, 2008 09:22 AM
