Difference between clutch discs?
Old Jan 5, 2006 | 03:53 PM
EK k kay's Avatar
Default Difference between clutch discs?
What is the difference between the performance street disc in the ACT HDSS kit and the stock street disc in the ACT HD00 kit? Both use the same ACT heavy duty pressure plate, but the difference is the clutch disc and $60. I know the HDSS is the better overall kit, but I want to know what I lose if I pick the HD00 kit over the HDSS kit? Both kits are rated at 223ft/lb of tq which is plenty for my boost needs.
Old Jan 5, 2006 | 04:18 PM
ekb16's Avatar
diff friction material
Old Jan 5, 2006 | 08:05 PM
EK k kay's Avatar
Default Re: (ekb16)
What is the difference in terms of me feeling it though?
Old Jan 5, 2006 | 08:07 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (EK k kay)
well if one os organic and the other ceramic, the organic will feel stock. the ceramic will chatter on engagement. i am assuming they are the differences.
Old Jan 5, 2006 | 08:25 PM
EK k kay's Avatar
Default Re: (boostedcivicsir)
They are both organic.
Old Jan 6, 2006 | 01:14 PM
EK k kay's Avatar
Someone has to know..
Old Jan 6, 2006 | 01:30 PM
Archidictus's Avatar
Unceasing Measure
The HDSS system will last longer under light-duty use and grip harder (but not last as long) under heavy-duty use because of the slightly different material composition.
If you want a specific answer, email ACT and I'm sure they'll tell you
Masatsu
Acura NSX
May 3, 2010 06:37 AM
FearDisH22a4
Sep 4, 2008 02:08 PM
Street Ghost
Aug 13, 2004 11:01 PM
yellowturbo
Oct 30, 2003 12:01 PM
crx1856
Jun 6, 2003 08:50 AM
