Not my IAC valve!!
Old Jan 5, 2006 | 03:49 PM
r1de4life's Avatar
Default Not my IAC valve!!
My car is having the same trouble as InvaderTrax is having. I pulled the IAC vlave today and cleaned it and it is still doing it. Could it possibly be the main relay? if not what are some other things that could be causing it?
Thanks
Old Jan 5, 2006 | 07:41 PM
ed_1's Avatar
Default Re: Not my IAC valve!! (r1de4life)
Next to the throttle body, like in top of it there's a adjusting screw. Use a flat head screwdriver while the car is on, and listen to the rpms. That might be your problem.
Old Jan 5, 2006 | 09:33 PM
amckee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r1de4life &raquo;</TD></TR><TR><TD CLASS="quote">My car is having the same trouble as InvaderTrax is having. I pulled the IAC vlave today and cleaned it and it is still doing it. Could it possibly be the main relay? if not what are some other things that could be causing it?
Thanks</TD></TR></TABLE>The problem InvaderTrax described does not sound like the idle surge that a bad IACV would cause. I would start by asking how old are the plugs, wires, rotor, and cap. Then I'd look at fuel pressure and supply.
bdj1973
Dec 5, 2014 07:00 AM
chrisna
Nov 12, 2007 08:42 PM
metal craft
May 29, 2007 08:53 PM
mikester_91
Jan 6, 2005 07:58 AM
crafty
Sep 3, 2004 04:09 PM
