Wiggling Shifter?
Old Jan 5, 2006 | 02:32 PM
FrOsTwHiTeDC4's Avatar
Default Wiggling Shifter?
Hey I just bought an ED7 recently and it came with a short throw shifter on it. When you put the car in gear you can move the shifter around like it is in neutral. I was wondering if anyone could help me solve this problem. If you need a video of what I mean i'll be glad to make one.
Albert
Old Jan 5, 2006 | 02:34 PM
CRX Toad's Avatar
Default Re: Wiggling Shifter? (Turbo'd B20B)
Check your bushing and see what they look like. May have some bad bushing that is creating you sloppy feeling.
Old Jan 5, 2006 | 05:12 PM
Cute EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Check your bushing and see what they look like. May have some bad bushing that is creating you sloppy feeling. </TD></TR></TABLE>i bought a civic with the same problem. except it was worse, because the owner had a bent rod in place of the bolt at the bottom of the shifter.
Old Jan 5, 2006 | 07:03 PM
mahatma's Avatar
Default Re: Wiggling Shifter? (Cute EK)
Mine did this too. Put urethane shifter bushings in and still didn't solve it.
Turned out to be that the linkage was loose where the bitch pin is. Check for play there.
Old Jan 9, 2006 | 11:24 PM
cr-rex88's Avatar
i had the same problem but it turned out it just wanst bolted down tight so look and see if its just the bold under the car.
Old Jan 9, 2006 | 11:26 PM
Jesterian's Avatar
24.243.141.75
Default Re: Wiggling Shifter? (cr-rex88)
Same problem, it was the bolt that connects the shifter to the tranny. Very easy to fix, really bad to have break when you're going somewhere.
Extreez
Dec 13, 2007 08:09 PM
vwtohonda
Aug 7, 2006 08:55 AM
CTR-GSR
Feb 24, 2006 09:47 PM
slash00R
Nov 1, 2004 07:23 PM
Regular Series
Sep 14, 2002 10:41 AM
