Starting issues i need help asap!!!
I have searched already!! Its a 92 si chassis with a jdm h22a in it. Well i have spark,fuel and compression and its still not doing anything, ive already changed out the ICM, dizzy, cap, rotor and plugs...ive checked the timing its good. what could it be? I heard that the main relay in these cars go bad could that be a cause? any input would be awesome! thanks alot.
You may want to go out and get a second set of spark plugs or clean the one's you have in and then have someone try starting the car while you turn the distributor. I thought I had my timing right on and the car wouldn't fire up and built up a lot of carbon on the plugs. Swapped them out (and cleaned the first set to have for a back up) and had my GF try starting it while I moved the distributor and it fired right up.
Hey it may not be the correct way of doing it but it fired up and I got the timing set dead on.
I am sure with the experience foating around here there may be some better advice but it's what I did.
^^^speedfreak77 i tried exactly what you had descirbed. I know i have fuel because my fuel pressure gauge on my rail is showing pressure when i try to turn the key, secondly i took out every plug 1 by 1 put it agaist the header and it got spark. im stumped i have no idea.
Just because your getting fuel to the rail doesn't mean you're getting it to the cylinders.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedFreak77 »</TD></TR><TR><TD CLASS="quote">It sounds like the injectors may not be working correctly. Maybe like IHateJDM said it's a problem with the resistor box.
HMMMMMMMMMMMMMMMMMMMMMM?????????
hey bro i just had this exact problem check the crank positioning sensor by the dizzy i had spark and fuel and thought it was timing but it was cps but just dbl check your firing order too 1-3-4-2 1 being by the dizzy hit me back
rocaveli
33
Jul 13, 2005 03:16 PM
Phaze1_Ls
10
Oct 2, 2003 03:48 PM
