anyone good at troubleshooting a 95 JDM H22A please help
Old Mar 19, 2002 | 05:03 PM
H22ACiViC's Avatar
New User
Default anyone good at troubleshooting a 95 JDM H22A please help
okay had some problems with injectors but i think i figured it out... another thing is i just have headers and downpipe on.. my problem is it won't rev higher than 3500 rpm it just like cuts off after that don't know if it is like a slight back fire or what but will not rev higher than 3500 rpm ?? any suggestions will help thanks
Old Mar 19, 2002 | 07:34 PM
aklucsarits's Avatar
New User
Default Re: anyone good at troubleshooting a 95 JDM H22A please help (H22ACiViC)
What CEL code(s) are you getting? Do you have the cat and O2 sensor plugged in yet?
Yep, you're gonna get a heck of a lot of backfiring when you are dumping right out the header...
Andrew
Old Mar 19, 2002 | 07:57 PM
H22ACiViC's Avatar
New User
Default Re: anyone good at troubleshooting a 95 JDM H22A please help (aklucsarits)
no not just out the headers i have the downpipe on too , also yes i have o2 sensor plugged in. i have no idea how to retrieve the codes on this car ? it is obd 1 i used to have obd 2 and new how too on that ...
Old Mar 19, 2002 | 08:02 PM
boomslang's Avatar
Jump the 2 prong service connector in the interior. Turn the key to the on position. Watch the CEL flashes.
Old Mar 19, 2002 | 08:06 PM
H22ACiViC's Avatar
New User
Default Re: anyone good at troubleshooting a 95 JDM H22A please help (Inlinefour)
where is the 2 prong service connector ? the obd1 h22 is in my 97 civic . which i had my 97 civic ex harness re-wired to work on the h22 ???
Old Mar 20, 2002 | 09:55 PM
KS-R's Avatar
It should be under the dash on the passenger side.. right by the ecu.. The connector has two wires.. the connector should be blue in colour ( unless they're different in the states)
Once you just the connector.. the CEL on the dash will flash a certain amount of times... a long flash will equal 10s.. and quick flashes mean 1s.. just count them and add them up.
Old Mar 21, 2002 | 04:52 AM
BoM's Avatar
BoM
Default Re: anyone good at troubleshooting a 95 JDM H22A please help (KS-R)
any vaccumm leaks?
later your going to need a fuel pump, it'll help. my friend had to get one, he had a civic pump for 100hp when he had a 200 hp motor (h22a) in it.
cpennington89
Feb 20, 2015 05:33 AM
swappedcx
Jan 13, 2006 02:33 AM
Cablerat
Apr 18, 2005 08:22 AM
motohatch557
Aug 21, 2004 10:09 PM
Ryu
Nov 8, 2002 08:54 AM
