ls/vtec gsr questions
ok heres my motor setup for the time being. right now i am just trying to get the car drivable, performance will come later.
i have a b18a1 bottom block and a b18c1 head
what exactly needs to be fone to the block and head before i can put the both together and mount in the car. i know that i need to weld and to drill some holes, and run the oil lines i just dont know how to do it or where exactley to tap the block for the oil, if anybody has some pics of a b18a1 block with the oil lines in on it. and what needs to be done witht the head to set up the oil lines and which holse need to be drilled. again pics would be great
You won't make it far on this forum if you don't make friends with this guy: https://honda-tech.com/zerosearch
Do an archive search for lsvtec build and you'll get alot of good threads.
Here's a start: https://honda-tech.com/zerothread?id=1036035
