My accord is running poorly
Old Jan 5, 2006 | 07:55 AM
MusickGirl420's Avatar
Default My accord is running poorly
I have a 2000 accord EX coupe with 126000 miles, I kept maintenance up to date, however I filled up with gas 2 days ago, since the fill up the car has difficulty starting for example it sounds like I have a bad spark plug then it will run fine.
Do I need to relace coil packs at this time or could it be a bad tank of gas.
Old Jan 5, 2006 | 11:04 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: My accord is running poorly (MusickGirl420)
run thru the tank and see if it improves after you fill up
Old Jan 5, 2006 | 11:49 AM
Honda-Master's Avatar
could be bad batch of gas, do as vt4,, suggested
Old Jan 5, 2006 | 03:24 PM
iam7head's Avatar
Default Re: (Honda-Master)
check your spark plug, check the rotor and cap while you at it.
look for carbon build up.
Glundin
Nov 18, 2013 06:51 AM
hondaaccordf23
Jan 11, 2012 10:46 AM
PGriff253
Oct 23, 2010 11:44 PM
A Tribe Called Honda
Oct 2, 2008 05:40 PM
NiBlazed
Oct 26, 2004 07:07 PM
