What do i need for rear disc brake swap for 89 crx hf?
Old Jan 5, 2006 | 07:52 AM
civicsleeper97's Avatar
Default What do i need for rear disc brake swap for 89 crx hf?
I just went to my mechanic and he checkedmy rear brake drums because they were squeking and i seen that the brake drum pads needed to be changed and he said he needed to resurface the drum cover a little. He says the job would cost me $300 and i trust his pricing. Just wondering if doing a rear disc brake system is cheaper and how hard of a job is it. Links and pics would help alot. I have a 89 crx hf and swapped a d15b vtec. Let me know
Old Jan 5, 2006 | 08:01 AM
HondaFerris's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (civicsleeper97)
def do a disk brake conversion. I got a complete conversion for my hatch for $75...use the rear disk brakes from a 90-93 integra or get them off of a crx si...search you will find alot of info on this...
Old Jan 5, 2006 | 10:11 AM
Targa250R's Avatar
be professional
Please use the search. The rear disc brake conversion is by far one of the most common topics on this board.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda-Tech.com Search Function &raquo;</TD></TR><TR><TD CLASS="quote">
» Search Results
Your search for disc returned 102 results.
» New Search
You will need the following things:
- rear hub assemblies for discs (attached trailing arms are optional)
- calipers (you can turn these in as cores for new or reman units)
- rotors (new, blank)
- pads (new)
- proportioning valve (the proper one will depend on which front brakes you are using)
- soft lines for calipers (fitting is different than for wheel cylinders)
- e-brake cables for calipers (fitting is different than for drums)
- fresh brake fluid (DOT 3 or DOT 4)
You can get the hub assemblies (with or without trailing arms), calipers, rotors, and pads from/for the following cars:
- '90-91 CRX Si
- '90-01 Integra (except Type-R)
- '92-95 Civic LX-ABS, EX-ABS, Si, Si-ABS
- '93-97 del Sol Si, VTEC
- '99-00 Civic Si
The soft lines and the e-brake cables you will need are for a '90-91 CRX Si.
The proportioning valve will depends on which front brakes you are using. Which front brakes are you using?
Old Jan 5, 2006 | 11:08 AM
Tyson's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (Targa250R)
ive got a 4040 proportioning valve available. $40 shipped.
oh and his pricing stinks. why would you trust him?
Modified by Tyson at 1:10 PM 1/5/2006
Old Jan 5, 2006 | 11:38 AM
SHJR89CR-X's Avatar
not trying to steal thread, but password jdm has a rear disc confersion for $150 do u guys know anything about what it comes with. I know it doesn't come with lines.
Old Jan 5, 2006 | 11:43 AM
EL Vap133's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (SHJR89CR-X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SHJR89CR-X &raquo;</TD></TR><TR><TD CLASS="quote">not trying to steal thread, but password jdm has a rear disc confersion for $150 do u guys know anything about what it comes with. I know it doesn't come with lines.</TD></TR></TABLE>
They're usually old rusted Civic rear disc brakes with no e-brake cables.
Old Jan 5, 2006 | 11:47 AM
SHJR89CR-X's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (EL Vap133)
Sooooo not worth it eh?
Old Jan 5, 2006 | 11:49 AM
CRXb18Turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsleeper97 &raquo;</TD></TR><TR><TD CLASS="quote"> He says the job would cost me $300 and i trust his pricing. </TD></TR></TABLE>
Your Mechanic must be on drugs.
Resurface drum is about 5-15 bucks each
shoe is about 30+ (oem)
Old Jan 5, 2006 | 12:01 PM
SiMateoAko's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (CRXb18Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXb18Turbo &raquo;</TD></TR><TR><TD CLASS="quote">Your Mechanic must be on drugs.
shoe is about 30+ (oem)</TD></TR></TABLE>
Agreed. He could buy new drums for less than that.
Old Jan 5, 2006 | 12:37 PM
mrsuburban's Avatar
Default Re: What do i need for rear disc brake swap for 89 crx hf? (SiMateoAko)
HAHA 300 for a rear drum job on a honda??? time for a new mechanic or better yet do it yourself but yea deff do a rear disk brake conversion its worth it
racingcrx
Nov 22, 2008 03:43 PM
socalrex88
15
Sep 8, 2007 10:51 PM
msantas
Apr 10, 2006 01:26 PM
lkist013
Jan 12, 2006 05:30 PM
BAZ
28
Sep 21, 2003 10:24 AM
