question about my car
Old Jan 5, 2006 | 06:08 AM
mcspd704's Avatar
Default question about my car
Okay, i have a 92 civic hatchback. i recently just did a b16 swap, and i have a P61 ECU (GSR), msd ignition, fluidyne radiator, headers, aem cam gears, and a walbro fuel pump hooked up to a fuel pressure gauge. My car starts up fine, but sometimes when i hit the throttle, i lose power (rpm goes down and it seems as though my engine wants to cut off, but it doesn't), i let up off the throttle and it goes back to normal idle. I do have a check engine light for the throttle position sensor. But i don't know what the heck is going on????I need help please!!!!!!!!!!!!!!!!!!!!
Old Jan 5, 2006 | 07:50 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: question about my car (mcspd704)
you need to grab a helms and start by diag'ing why it is throwing a tps code.
Old Jan 5, 2006 | 07:58 AM
SHG_Beans's Avatar
Maybe you have a bad throttle position sensor.
Old Jan 5, 2006 | 10:35 AM
mcspd704's Avatar
Default Re: question about my car (boostedcivicsir)
hey, thanks for the reply. COuld the TPS throw my ecu off or something. When i press the gas slowly, i mean slowly, it revs and powers up. it just when i press it instantoues(as if i was come out of first) it loses power. i talked to some autozone folks, and they said it could be my fuel filter??!!
Old Jan 5, 2006 | 10:46 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcspd704 &raquo;</TD></TR><TR><TD CLASS="quote">hey, thanks for the reply. COuld the TPS throw my ecu off or something. When i press the gas slowly, i mean slowly, it revs and powers up. it just when i press it instantoues(as if i was come out of first) it loses power. i talked to some autozone folks, and they said it could be my fuel filter??!!</TD></TR></TABLE>
it could be your tps. it could also have to do with your fuel pump. When you slam on the gas, your injectors dump a bunch of fuel in the cylinder before it has time to suck up enough air for that amount of fuel. If you are running rich to begin with (because of your fuel pump), then when you go WOT, you are dumping so much fuel in that it bogs the motor. your tps would play into this some too (that's how your ecu knows how far down your gas pedal is).
If your motor internals are stock, you really don't need an aftermarket fuel pump (I know this from experience).
Old Jan 5, 2006 | 10:57 AM
Stingray96's Avatar
i thought the p72 was the gsr ecu...i think you have the wrong ecu or read it wrong or something
Old Jan 5, 2006 | 11:22 AM
mcspd704's Avatar
Default Re: question about my car (IHateJDM)
it has done this problem before i put the new fuel pump in (i know it was rich before because black **** was coming out the exhaust), i sincerly think it's the TPS sensor. i got my fuel pressure gauge hooked up, it reads 20psi at idle, then 25-30 PSI on the gas.
Old Jan 5, 2006 | 11:55 AM
tpr's Avatar
tpr
Was it running fine after the swap or this is a new symptom. If it has done it all along, then the TPS may be wired backwards. When you hit the throttle the ECU thinks the throttle is closing rather than opening. See if you have the proper voltages at the TPS (0.5 VDC at Idle and 4.5 at WOT (wide open throttle)).
92gsrlord
Mar 17, 2011 07:14 PM
Sanchez201
Jul 9, 2009 08:06 AM
hondaokie
Jan 14, 2005 01:28 PM
CrX-To-Tha-Max-v2.0
Nov 20, 2004 03:05 PM
LD_EGSICK
May 15, 2002 07:04 PM
