clicking under glove box, fuel pump wont prime......PLEASE HELP!!
Old Jan 4, 2006 | 11:02 PM
xd69's Avatar
Default clicking under glove box, fuel pump wont prime......PLEASE HELP!!
we swapped out my blown h22 with another jdm h22. when i turn the key to the on position(turn the key twice) i get this clicking coming under the glove box, car wont start and the fuel pump will not prime. took the glove box out and it seems like it's coming from a relay. we tightened the ground to the starter and the car fired up, no clicking, then my tach started jumping crazy and the car just died. we fired it up a couple of minutes later and the clicking was still there but the car still fired up(for some reason) then the car died again. now the car wont start, the fuel pump wont prime and the clicking is still there.
need help asap
t.i.a.
Old Jan 5, 2006 | 12:24 AM
postman's Avatar
Default Re: clicking under glove box, fuel pump wont prime......PLEASE HELP!! (xd69)
relay is bad. new one, or there is a break somewher in the line.
Old Jan 5, 2006 | 02:23 AM
CiViC I2aCeI2
Guest
Posts: n/a
Default Re: clicking under glove box, fuel pump wont prime......PLEASE HELP!! (postman)
how do you know if your fuel pump isn't priming?
Old Jan 5, 2006 | 02:40 AM
ekb16's Avatar
check your grounds...there should be 3...this happened to me b4..
Old Jan 5, 2006 | 09:20 PM
xd69's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds...there should be 3...this happened to me b4..</TD></TR></TABLE>
can you tell me where they are at?
bump
Old Jan 6, 2006 | 02:51 AM
xd69's Avatar
Default Re: (xd69)
problem solved, it was a lose ground. now im throwing cel 22.
thanks guys
worx
13
Oct 24, 2010 12:11 PM
teg racer 877
Mar 5, 2009 05:40 PM
igone916
Oct 7, 2007 10:21 PM
H22CL
Aug 1, 2005 05:43 AM
