Gsr belt dont Fit at all
Old Jan 4, 2006 | 10:21 PM
Ruben19's Avatar
Default Gsr belt dont Fit at all
i have a b18c1 block and a b16a2 head. i bought a gsr timing belt but is way too ong. i also tried the si belt but still too long. I dont know what belt should i use.
please let me know ASAP. i need to ge this car done?
the gsr block has a longer stroke than the b16 block. and i thing the si head is shotter by a couple of inches. I was told to use the gsr belt but im surprise that the si belt dont even fit at all.
Old Jan 4, 2006 | 10:38 PM
Supernatural's Avatar
Default Re: Gsr belt dont Fit at all (Ruben19)
what water pump are u using?
Old Jan 4, 2006 | 10:42 PM
onepoint6i's Avatar
Default Re: Gsr belt dont Fit at all (Supernatural)
w3rd, you have the wrong pump on there or something...
Old Jan 4, 2006 | 10:43 PM
Ruben19's Avatar
gsr water pump. but the i think the si is the same pump. im using gsr cams, b16a2 oil pump and tensioner. but the gsr belt still too short and si too
Old Jan 4, 2006 | 10:45 PM
onepoint6i's Avatar
Default Re: (Ruben19)
you have something wrong going on...are you routing it right? im not calling you dumb but the GsR belt is the belt you need...it has to fit perfect..
Old Jan 4, 2006 | 10:52 PM
Ruben19's Avatar
so why the si belt dont even fit
Old Jan 4, 2006 | 10:57 PM
unless u have 2 si belts and dont know it....the si belt is shorter than the gsr and ls
Old Jan 4, 2006 | 11:05 PM
Ruben19's Avatar
i will check the belt tensioner.
if is in the right place.
Ruben19
Jan 5, 2006 07:04 AM
Ruben19
Jan 4, 2006 11:13 PM
Ruben19
Dec 23, 2005 05:04 PM
mycrx7
14
Jun 14, 2005 02:14 AM
infamousALLMTR
Feb 25, 2003 07:17 PM
