CRX Wiring Gurus Needed!!!
Old Jan 4, 2006 | 10:10 PM
Ralph Wiggum's Avatar
Default CRX Wiring Gurus Needed!!!
My crx was recently broken into and really did a hackjob on the stereo harness. I drove the car without a stereo and noticed that the tach and speedometer and basically the whole cluster would move erratically when i used the turn signals, high beams, hazard lights, etc. I had a stereo installed and I figured that it would solve the problem but it hasn't. I don't think its the turn signal relay because I just replaced it and I checked the fuses and they all look intact. Is there a ground that's missing inside the center console or is it a totally different wiring problem?
Thanks
Old Jan 5, 2006 | 04:47 PM
bump
Old Jan 5, 2006 | 05:52 PM
zccr-xsi's Avatar
Default Re: CRX Wiring Gurus Needed!!! (Ralph Wiggum)
did it all work before it was broken into?
Old Jan 5, 2006 | 11:36 PM
Default Re: CRX Wiring Gurus Needed!!! (vteckillenzc)
Yeah everything worked perfectly until those rat bastards touched her. It's a JDM CRX cluster. The only thing that didn't work was the low gas light and the doors on the mini car diagram because I didn't wire it. Someone help cause I suck at anything electrical!
Old Jan 6, 2006 | 03:01 AM
VegaS10's Avatar
The car stereo has zero to do with the cluster.
The ONLY wire they share in common is illumination/dimmer.
Other than that, it sounds like the same symptoms I had when I was doing my gsr cluster swap. It was a bad/loose groujd.
KevinEF7
13
Jul 26, 2013 10:35 PM
B20EF
Jan 26, 2006 03:06 PM
88rexboy
Mar 28, 2004 11:08 AM
89crxzc
Sep 10, 2003 08:04 AM
