96 Accord-- aiming headlights
Old Jan 4, 2006 | 09:02 PM
thanksandgigem04's Avatar
Default 96 Accord-- aiming headlights
Suppose I had a headlight that is not in-line with the other and points off to the right. How do I aim the headlight?
Thanks in advance for any advice.
Old Jan 5, 2006 | 01:15 PM
halalboy2000's Avatar
Default Re: 96 Accord-- aiming headlights (thanksandgigem04)
i'll try to do this without pics...here goes
open up the hood and look on near the edge of the head light closest to the fender you'll see white colored plastic cylinder thingy...there's a screw in there that you turn to aim up or down. you access the head of the screw thru the front of the headlight.
hope that helps.
Old Jan 5, 2006 | 02:00 PM
P_Adams's Avatar
This is going to be difficult to discribe without pictures, but I'll give it a try.
Adjustments can be performed with a long shank phillips screwdriver (9" to reach the lower (Side to Side) adjuster)
Adjustments to the left side are easy(er)
Adjustments to the right (lower) require removal of the radiator overflow to gain access.
The bottom adjuster looks like a square box which protrudes out the back of the headlamp near the bottom, almost directly aligned under a 1/2" hole on the top of the Radiator Support. With a flashlight, if you look directly into the top of this, you'll see a toothed wheel. You rotate that wheel in/out using the blades of your Phillips Screwdriver. That adjusts the headlamp side to side..
The top adjuster looks like a 3/8" (head diameter) phillips screw which is mounted horizontally. This adjusts the headlamp up/down
P
Old Jan 5, 2006 | 09:25 PM
Default Re: 96 Accord-- aiming headlights (P_Adams)
Hey thanks guys, Ill give it a shot when I get a chance this weekend.
Thanks again.
Old Jan 6, 2006 | 01:30 AM
2+2=5's Avatar
look for a dark as sin level parking lot, aim straight to a wall(if they have a brick one, that's even easier to see) at 25ft away.
make sure everything is line up, drive around, if you don't like the position, go back and make final adjustment.
Danger69
Oct 28, 2009 02:43 PM
patrickstar
11
Feb 21, 2009 11:41 PM
mrtrinh
Honda Civic (2001 - 2005)
Oct 8, 2008 11:29 AM
bakakuso2
Jul 13, 2008 07:58 AM
flybert
Aug 4, 2002 03:45 PM
