Alternator or ???? on my 89 Si
Old Jan 4, 2006 | 08:16 PM
JDM_EK_JOE's Avatar
Default Alternator or ???? on my 89 Si
k guys, my car wouldnt start today in my driveway. Like nothing was on, it wasnt even turning over. i got a boost and then it went on. then when i dropped my grandmother off it died again on me. I finally got to my work (acura) and then i decided to try to charhe the battery. I left it for a good 2 hours. Then I removed the charger and it still wouldnt start. Then i go home and get the battery out of my parts car, (i know that works cause its 2 months old) so i install it and then it didnt work??? so then i come to a conclusion that maybe its the alternator. I did that "remove the positive terminal test" and when i removed the positive terminal, the car didnt shut off. WTF???
The car is a 89 civic Si with a SOHC ZC
Old Jan 4, 2006 | 09:05 PM
Rob.'s Avatar
Default Re: Alternator or ???? on my 89 Si (91Civic_Joe)
do a search bro.
Old Jan 4, 2006 | 09:15 PM
JDM_EK_JOE's Avatar
Default Re: Alternator or ???? on my 89 Si (Rob.)
just did the alternator test (remove the positive terminal when the car is running, should shut off if bad alternator) It didnt shut off???
Old Jan 4, 2006 | 09:18 PM
EFJap91's Avatar
whatsup man so ur car wont start regardless of wiether or not the battery is new or old?? I am guessing that it is a five speed right?? isnt there some sort of switch or sensor that deals with the clutch being engaged so that the car will start.... i dont really think its ur alternator because in the past you would have experienced trouble with it starting and then not starting off and on.. and check all ur grounds because if one is a little loose or frayed your battery will drain itself...
Old Jan 4, 2006 | 09:46 PM
JDM_EK_JOE's Avatar
Default Re: Alternator or ???? on my 89 Si (EFJap91)
I just bought the car 2 days ago so i dont know if there was a problem.
Old Jan 4, 2006 | 09:49 PM
Rob.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Civic_Joe &raquo;</TD></TR><TR><TD CLASS="quote">.... I did that "remove the positive terminal test" and when i removed the positive terminal, the car didnt shut off. WTF???
The car doesnt run off the battery, it runs off the alternator.
The battery is only there to start the car...
It think it's one of these:
1. main relay
2. Ignition problem
3. Bad ground
4. Battery leads
5. your smoking too much pot.
or even a bad fuel pump
If it was your alternator, your battery light on the dash would flicker, your RPM guage needle would start to bounce, and your car will feel like dying.
Old Jan 4, 2006 | 10:05 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">The car doesnt run off the battery, it runs off the alternator.
Cars act funny if the battery is absent. The battery acts as a capacitor, fronting energy for all the **** in your car and compensating in the event that the alternator cannot supply it all at that moment. Like the time the positive fell off my battery while I was driving, when I sat at a stoplight at idle my CD player and dash and everything shut off, but came back to life right when I started going again.
But yea at least we know your alternator is working.
Check starter leads and stuff?
Unphzd
Jul 14, 2011 09:15 AM
robble36
Oct 18, 2007 05:19 AM
caliek4
Apr 19, 2006 03:35 PM
kaotikcrx05
Feb 3, 2005 08:08 AM
lawlerlaw
Jan 8, 2005 02:12 AM
