autozone piping...
i believe all the piping from autozone or pepboys is galvanized
if you do weld it make sure your in a well ventilated area
and dont sit over the part when your welding it because of the fumes and you should be fine
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">no it is aluminized. which is ok to weld. (always need ventilization when welding however)
galvanized is like the fences at little league baseball fields...also at Lowes..</TD></TR></TABLE>
yea the piping that looks like it has flakes in it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">no it is aluminized. which is ok to weld</TD></TR></TABLE>
You sure about that ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">yep...prep it and weld
You did not say prep the first time, I'm pretty sure aluminized can also be bad if you weld it.
</TD></TR></TABLE>You did not say prep the first time, I'm pretty sure aluminized can also be bad if you weld it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">You did not say prep the first time, I'm pretty sure aluminized can also be bad if you weld it.</TD></TR></TABLE>
Either way, there's usually copper on filler rod (or wire) and if I remember right that's even worse...
Always best to be safe and have a fan circulating air around
doesnt matter when i said it...the fact is it can be welded, regardless of what steps you need to take before hand...
same as saying anything in a wrapper can be eaten...oh you must unwrap it first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr »</TD></TR><TR><TD CLASS="quote">doesnt matter when i said it...the fact is it can be welded, regardless of what steps you need to take before hand...
But a lot of people won't grind the aluminized off when they mig weld it. It just seemed like you said aluminized piping was ok to weld on, when in fact its not. If you prep it, and grind the aluminized of then it is. But then so is galvanized piping, if you prep that, and grind the galvanized off, you basically has the same pipe as the aluminized pipe.
I just wanted to make sure you need to grind the aluminized off. And drink milk a day before hand. Just in case.
</TD></TR></TABLE>But a lot of people won't grind the aluminized off when they mig weld it. It just seemed like you said aluminized piping was ok to weld on, when in fact its not. If you prep it, and grind the aluminized of then it is. But then so is galvanized piping, if you prep that, and grind the galvanized off, you basically has the same pipe as the aluminized pipe.
visionsOFmadness
Feb 29, 2004 10:18 AM
