Smaller rad for the ef?
Old Mar 19, 2002 | 03:26 PM
warfa's Avatar
Default Smaller rad for the ef?
Would it be possible (would it even be beneficial?) to mount an eg rad onto a ef? This will free up a lot of space for a turbo, intercooler, oil cooler, etc. Has anyone done this? Have pics of the install and finished product?
Old Mar 19, 2002 | 06:23 PM
balistic CRX's Avatar
Default Re: Smaller rad for the ef? (warfa)
yeah it would be possible but you would have to weld some brackets for it to be good and sturdy.
Old Mar 19, 2002 | 07:14 PM
Louie B.'s Avatar
Place Racing makes a kit to put one in, the smaller radiator won't cool as well, but it makes more room for the turbo. they've been advertising them in super street and other mags.
Try a search, this question has come up recently. You might be able to get some more info.
Old Mar 19, 2002 | 07:34 PM
RedRacerCivic's Avatar
Default Re: Smaller rad for the ef? (thumpu77)
i thought it would cool the same casue its the DUAL CORE radiator
ef ect's Avatar
i beleave the smaller radiator will cool as well have herd that they are dobled cored or somthing to that effect, only problem is the hoses would behard to fit to the new radiator. if it cools in the eg why not as good in a ef besides it will sit next to a turbo
Old Mar 19, 2002 | 07:51 PM
Louie B.'s Avatar
Default Re: Smaller rad for the ef? (89SivicHatch)
Sorry, not cooling as well was my assumption (and the opinion of people in the past threads) I don't know for sure.
Old Mar 19, 2002 | 08:06 PM
warfa's Avatar
Sorry, I did try and do a search but I couldn't find anything. Well, I figured if they are using the half sized rad to cool a d16z6, then it must be better than the d16a6 rad. I already have a d16z6 swap and am finding it too weak. Interested in doing a junkyard turbo for it and would like to free up as much room as possible for a intercooler, oil cooler and compressor. I was hoping someone did a junkyard eg rad conversion for an EF. Doesn't appear to be that hard. I could probably bend/drill/curse/make my own brackets. For rad lines, wouldn't I be able to just use d16z6 compenents? I don't want to spend $300 cdn for a new rad and it not to work. So i was hoping someone else has tried what I'd like to.
Old Mar 19, 2002 | 08:20 PM
Louie B.'s Avatar
https://honda-tech.com/zerothread?id=136819 https://honda-tech.com/zerothread?id=125531 https://honda-tech.com/zerothread?id=104937
these might help..... none of them are the ones i was looking for, but they give some good info.
Old Mar 20, 2002 | 04:24 AM
warfa's Avatar
Thanks, that's what I was looking for sort of. Anyone got pics of the setup? A parts list? Has anyone tried the dodge neon approach?
LuckyJDM
May 20, 2013 07:15 PM
spens 91 Ef
Dec 18, 2012 08:56 AM
shosek03
Mar 25, 2008 11:33 AM
Jdmsolutions
Welding / Fabrication
24
May 12, 2007 05:14 PM
