NEED HELP WITH B20 VTEC CAMS
I was wondering if someone could give me some good adivce in regards to camshafts for my car.
will be runing B20 Z with GSR head. Bottom end is fresh, but somewhat stock. Currnetly has knife edged crank and balanced. Fresh piston rings and bottom end bearings. Flycut the pistons. Decked the top of the block. head will be ported with Ferrera valves and valve guides. supertech valve springs and retainers, Skunk Pro series intake manifold, skunk Pro series 70mm throttle body. Skunk cam gears. full exhaust, no catalytic, fuel system aswell. 255 intank pump, paxton fuel pressure regulator, Aem fuel rail, all fuel lines replaced with dash 6 braided line (ALL BANJO FITTTINGS ARE REMOVED). b16 tranny, ITR flyweel and pressureplate, 4 puck clutch. Was running Toda B cams last year. was working good. Had great bottom end and midrange but no top end. Friends of mine with B20 vtecs making more power than me with skunk2 stage 2 cams (NON PRO SERIES).
I am really interested in Pro series cams, but not sure if they will work well. Havent heard too much about the as of yet.
Can someone please recomend a GOOD camshaft to me please.
Thank You
Dallio
Thank You
Dallio
vtecmasta85
80
Oct 22, 2015 08:23 AM
2 0 3
Aug 17, 2003 06:45 PM
