Code 20 ELD...converting from obd0 to obd1
Converting to obd1 using the rywire harness. I have a hasport engine harness as well. Using a dizzy king obd1 dizzy. Car will not start after wiring up everyting like im supposed to. No matter what I unplug or switch around at the dizzy plug for tdc, crank, or cylinder position I only throw code 20 eld. If i have one of the 7 sensor wires unplugged should it not throw a code for this? The car just turns over and over. Checked for spark at each plug and not getting any spark.
Any help would be niiice.
which plug is d10? i thought the ecu plugs were labeled a,b, and c should i wire b19 into d10?
