OBD0 ENGINE MANAGEMENT OPTIONS FOR BOOST
Old Jan 4, 2006 | 06:00 PM
Freeltec's Avatar
Default OBD0 ENGINE MANAGEMENT OPTIONS FOR BOOST
here is my setup:
89 EF
b16a1 head
98 gsr cams
ARP HEAD STUDS
Cometic head gasket
b18a bottom end
9.1 arias pistons
stock rods
t3/to4e .57 turbo
7psi sprung external wastegate to amosphere
Ls cable tranny(no lsd)
vafc and 450dsm's
just a few questions for you guys:
I cant afford to go OBD1 right now, so what are some obd0 options for management?
i would like to boost 12psi and have at least 300whp.
what options do we EFers have?
Old Jan 4, 2006 | 06:14 PM
SVOboy's Avatar
TurboEdit, check out http://www.pgmfi.org
red_crx's Avatar
Default Re: OBD0 ENGINE MANAGEMENT OPTIONS FOR BOOST (Freeltec)
you can use turbo edit....a few of my friends use it
Old Jan 4, 2006 | 06:15 PM
SVOboy's Avatar
And mehbe BRE for you since you're b16a1 head and all. Chipped pw0/pr3, (see sig).
Old Jan 4, 2006 | 06:45 PM
shawn_crx's Avatar
Default Re: (SVOboy)
I'm planning to go turboed too.
Old Jan 4, 2006 | 06:51 PM
DocSean's Avatar
bre for sure, it get two thumbs up for me!
Old Jan 4, 2006 | 07:39 PM
red_crx's Avatar
Default Re: (spankjelly)
from the looks of it...BRE looks like good software
Old Jan 4, 2006 | 08:48 PM
Freeltec's Avatar
wtf is bre?
Old Jan 5, 2006 | 12:37 PM
SVOboy's Avatar
Go to http://www.pgmfi.org, it's the obd0 vtec tuning program.
Old Jan 5, 2006 | 03:18 PM
Keith Pierson's bitch's Avatar
i have an obo0 missing link if your interested and the greddy blue box
Old Jan 5, 2006 | 03:34 PM
DocSean's Avatar
Just got my car tuned today with BRE...however, ben still has some work to do on the launch limiter.....everything else works just peachy though!!!
Old Jan 5, 2006 | 03:45 PM
SVOboy's Avatar
What's wrong with the launch?
Old Jan 5, 2006 | 07:08 PM
DocSean's Avatar
For one when the launch is check, the engine won't switch to the high cam and revlimit drops to 6800. Also, it is off by 1k rpm's. For instance, if you set the launch limiter to 4500, it actually kicks in at 3500.
90R3x
Engine Management and Tuning
Mar 8, 2015 05:02 AM
Freeltec
Feb 8, 2006 06:13 PM
Freeltec
Jan 16, 2006 11:31 PM
Freeltec
Jan 10, 2006 06:59 PM
Freeltec
Jan 7, 2006 09:53 PM
