Replaced waterpump - Still Whirring noise
Old Jan 4, 2006 | 04:55 PM
dpkelly's Avatar
Default Replaced waterpump - Still Whirring noise
I replaced my waterpump and the accessory belts. When the accessory belts are off (alternator, power steering) I'm still hearing a whirring noise down where the crankshaft is.
It's kind of like a whir whir whir sound. Could it be my oil pump or maybe some other bearing. I didn't change the tension pulley.
The whiring noise is louder at warmer engine temperature and doesn't go in when pushing the clutch.
Anybody with the same situation and solved this???
Old Jan 4, 2006 | 05:01 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Replaced waterpump - Still Whirring noise (dpkelly)
take off the dizzy cap and see if there is any red death in there. the dizzy may be goin south.
Old Jan 4, 2006 | 05:49 PM
dpkelly's Avatar
Default Re: Replaced waterpump - Still Whirring noise (boostedcivicsir)
There's that red dust that's in there. It's always been there and I just replaced it a few months back. The sound doesn't come from there though.
Old Jan 4, 2006 | 07:11 PM
Tippyman's Avatar
is it a "belty" noise. could be da timing belt... how does it run?
Old Jan 5, 2006 | 04:13 AM
dpkelly's Avatar
Default Re: (Tippyman98)
The timing belt is kind of new (46,000miles). It runs great now that I replaced a seizing waterpump. That whirring noise has me somewhat worried. I hope I don't have air in my coolant system.
Old Jan 5, 2006 | 05:07 AM
dpkelly's Avatar
Default Re: (dpkelly)
I just thought. I didn't replace the T/B when I replaced a siezing waterpump. It could be that my timing belt is stretched?????
Old Jan 6, 2006 | 07:44 PM
dpkelly's Avatar
Problem solved. It's the timing belt tensioner pulley. I removed the lower timing belt cover (after removing the crank pulley of course) and listened with a screwdriver up against the tensioner bolt. Makes a hell of a whirring noise. Also when the car starts up cold, I could hear a slight squeak sound even with new accessory belts.
Can't wait to fix it tomorrow and not have to worry about timing belt issues anymore (at least for a while).
Old Jan 6, 2006 | 09:32 PM
.Kevin.'s Avatar
ekk is that what it is i get that once in awhile.... i would have to have to take the timing belt all off again is there an easy way around it?
Old Jan 7, 2006 | 04:51 AM
dpkelly's Avatar
Default Re: (Slow_CvC99)
You just have to take the timing belt off of the pulleys. You don't have to remove it completely from the car and you can leave the engine mount on. So doing this job is pretty easy.
Old Jan 8, 2006 | 06:08 PM
dpkelly's Avatar
I changed the tensioner and it still makes that whirring noise in the same area. I think my timing belt was stretched a tad by a bad waterpump/tensioner. It might not be fitting 100% into the belt grooves. Man, I'm stumped. Any other possibilities???
Old Jan 9, 2006 | 07:04 AM
dpkelly's Avatar
Bump.
Old Jan 9, 2006 | 01:00 PM
blacksihatch's Avatar
SOUNDS LIKE YOU BOUGHT ONE OF THOSE TURBO WP, COOL.
Just kidding hope you get it resolved.
Old Jan 11, 2006 | 10:13 AM
dpkelly's Avatar
Default Re: Replaced waterpump - Still Whirring noise (blacksihatch)
I'm going to check my dizzy assembly to see if it's starting to seize up eventhough it's not making any noises. Years ago it was making horrible screeching noises and I took it apart and added WD-40 to the squeaking parts. It stopped squeaking but now maybe something is seizing up inside.
Old Jan 11, 2006 | 10:29 AM
MRlude2u's Avatar
My brother had the same problem, i think i know exactly what your talking about... He took it into our local honda dealer and had them adjust the tensioner pully like u said.... I think maybe tou just need to play with it a little bit. he went back like 3-4 times b4 they got it quite right. dont give up!
Old Jan 11, 2006 | 11:02 AM
dpkelly's Avatar
Default Re: Replaced waterpump - Still Whirring noise (MRlude2u)
Thanks!! That will be the next thing I'll do is re-adjust the T/B tension. At least I don't have to remove the lower cover (if I don't skip a tooth that is).
Old Jan 11, 2006 | 02:48 PM
dpkelly's Avatar
Default Re: Replaced waterpump - Still Whirring noise - update
Ok, I pulled the dizzy and definitely no seizing at all. Moves very easily. I'm now getting that rattling sound like the waterpump is going at low RPMs while in gear. After the new waterpump was on, this sound went away and it's back !
While the engine's hot, the upper rad hose seems to have air in it since it seems squishy yet the overflow bottle is at max. Are there air bubbles in my coolant? Headgasket failure? I fear there is an air pocket near the waterpump and it's running dry. Now I'm totally stumped. Could it be that my camshaft bearings are seizing up?
Old Jan 11, 2006 | 03:06 PM
pumpkyn's Avatar
my car makes the same whiring sound. does it get louder when you accelerate?
also my car has like a pulsating whir at idle
Old Jan 11, 2006 | 03:45 PM
dpkelly's Avatar
Default Re: (pumpkyn)
That's it!!! My theory is that a head gasket failure is causing air pockets to get into the coolant and making the waterpump run dry.
I get the ping/rattle sound under low RPM while in gear. After I replaced the waterpump, it went away but the whirring sounds stayed. I think I have more than one issue to deal with. I'll try and burp the air out of the system tonight.
If I see exhaust gases coming out of the coolant, most likely a head gasket failure. I guess.
Old Jan 12, 2006 | 12:45 PM
dpkelly's Avatar
ok next step is to check the timing belt tension. Several places on the web show the belt should twist 90 degrees between crank and cam. Tight belts do make a whirring sound. If the sound goes away then good.
If the sound remains, then i believe the head is warped putting stress on the camshaft which puts stress on the belt. At this point I'd have to get a newer cylinder head that is flat. More money to spend on an old high mileage car....
Old Jun 7, 2007 | 06:01 PM
budomove's Avatar
Hi, Did you ever solve the whirring sound around the tensioner pulley? What was it, if you don't mind, I think I may have the same problem.
Thanks, Frank
Old Jun 8, 2007 | 05:38 AM
ek4_b16a's Avatar
Default Re: (budomove)
my buddy that works on these cars says that it is the new water pump at work...after awhile, the whirring noise will go away...no worries...i had that happen on my swap when i swapped a b16 into my hatch...now it doesn't whir anymore...
raybo
Jul 8, 2012 11:14 AM
civic_driver
21
Jun 7, 2009 05:01 PM
VIS250P
Jan 4, 2005 01:21 AM
VIS250P
Jan 4, 2005 12:49 AM
timbuktu
Mar 19, 2002 05:48 PM
