Bad Bad Vibration 1996 Honda Accord EX
Old Jan 4, 2006 | 03:27 PM
BodyKits NW's Avatar
Default Bad Bad Vibration 1996 Honda Accord EX
Well a few weeks ago I replaced my front brakes. New Rotors, Wheel Bearings, Calipers..basically the works. I even replaced both axles because my boots were tore. On the way back from Portland my car starts to vibrate bad. I thought maybe it was because I didn't torque my axles nuts. I torqued them today and they are way tight. So I don't think that's the problem. I thought maybe it was because my tires were worn on the inside. I have had my tires worn on the inside quite a few times and it never caused me a problem. So with both tires replaced I still get a bad vibration. The vibration is there during decel and accel, and usually above 20mph. I do not know what else I can replace. Can bad struts be the problem? I am running out of ideas here. Any help would be great, thanks guys.
Old Jan 4, 2006 | 04:07 PM
Honda-Master's Avatar
sounds like separated ply ina tire,,,,,,,,inner cv joints worn,, loose suspension parts,,
I would start by inspecting tires for any bulges or severe flat spots , then rotating tires see if vibration changes at all....
Old Jan 4, 2006 | 04:09 PM
i20ar's Avatar
Default Re: (Honda-Master)
maybe broken motor mounts?
Old Jan 4, 2006 | 04:13 PM
YeuEmMaiMai's Avatar
check your ball joints and tire balance
Old Jan 6, 2006 | 07:28 PM
Default Re: Bad Bad Vibration 1996 Honda Accord EX (BodyKits NW)
Any other ideas?
Old Jan 6, 2006 | 08:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BodyKits NW &raquo;</TD></TR><TR><TD CLASS="quote">Any other ideas? </TD></TR></TABLE>
did you chk all the suggestions that were given to you ?? Or did you not like those suggestions?? did you chk the inner cv joints ?? did you chk anything at all ??
Old Jan 6, 2006 | 08:13 PM
Ross 2.0's Avatar
In a Junkyard near you.
No mean to offend if i'm wrong but you did put everything back together propperly (all suspension and steering) after you had the whole nucke off? Seems like something may have not made it back in the right way.
dtrophy
Apr 30, 2017 12:36 PM
cedrichawkda6
Dec 10, 2010 09:25 AM
ch4nq
May 25, 2006 09:51 AM
DC2SIR-G
Mar 11, 2006 01:55 PM
VTECcnIT
Suspension & Brakes
Feb 16, 2006 03:18 PM
