fmu???
Old Jan 4, 2006 | 03:03 PM
zccr-xsi's Avatar
Default fmu???
does anyone know if a can use a vafc in place of a fmU???please rpley asap!
Old Jan 4, 2006 | 03:06 PM
crxnj's Avatar
Default Re: fmu??? (vteckillenzc)
It would be best to use both..Because the fmu adds fuel and all the vafc does is subtract fuel..Using both of those you could get some pretty good a/f's
Im assuming you are boosted
Old Jan 4, 2006 | 03:08 PM
zccr-xsi's Avatar
will it be ok to run stock injectors with vafc? with boost?
Old Jan 4, 2006 | 03:10 PM
crxnj's Avatar
Default Re: (vteckillenzc)
Whats your setup..? And how much HP are you making or intending on making?
Old Jan 4, 2006 | 03:13 PM
zccr-xsi's Avatar
d16 vtec with turbo from thunder bird. turbo
im posting for freind and he wanted to know if he could do that or just run low boost with stock injectors?then tune with vafc?
Old Jan 4, 2006 | 03:17 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">d16 vtec with turbo from thunder bird. turbo
im posting for freind and he wanted to know if he could do that or just run low boost with stock injectors?then tune with vafc?</TD></TR></TABLE>
Well no..Because with added air you will need added fuel..The vafc alone and stock injectors will only subtract fuel..
Old Jan 4, 2006 | 03:18 PM
zccr-xsi's Avatar
now can i use fmu with stock inj?
Old Jan 4, 2006 | 03:20 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">now can i use fmu with stock inj?</TD></TR></TABLE>
Yes..But you will need a high flow fuel pump also with this setup As the fmu dumps crazy amounts of fuel into the motor over 5psi..
Old Jan 4, 2006 | 03:23 PM
zccr-xsi's Avatar
thanks for the help man
Old Jan 4, 2006 | 03:46 PM
mycrx7's Avatar
fmu=fucked managment unit, get a socketed ecu with a basemap, and dsm 450's cheap insurnace.
Old Jan 4, 2006 | 03:48 PM
SVOboy's Avatar
Default Re: (mycrx7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycrx7 &raquo;</TD></TR><TR><TD CLASS="quote">fmu=fucked managment unit, get a socketed ecu with a basemap, and dsm 450's cheap insurnace.</TD></TR></TABLE>
Indeed. I just did an ecu for nekoabandonded and I think this is the fifth or sixth time he's rebuilt his z6 after blowing it up on a combination of stock injectors, fmu, and vafc. , poor guy, just got his vtec working too.
Old Jan 4, 2006 | 05:04 PM
crxnj's Avatar
Default Re: (SVOboy)
Most fmus suck..But the aeromotive digital fmu is pretty nice..But for the price of one you can have a chipped ecu,45o inectors,and upgrader fuel pump..
Old Jan 4, 2006 | 06:17 PM
zccr-xsi's Avatar
yea! im chipping a pr4 for me when i boost the zc, but like i said i was posting for someone.he dont want to wait to get the ecu rechiped.
Old Jan 4, 2006 | 09:24 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckillenzc &raquo;</TD></TR><TR><TD CLASS="quote">dont want to wait to get the ecu rechiped.</TD></TR></TABLE>
There's never time to do it right, but there's always time to rebuild the engine. Funny how that works huh.
Old Jan 5, 2006 | 03:13 PM
zccr-xsi's Avatar
Default Re: (31flavorscivic)
u got the right
Old Jan 6, 2006 | 07:23 AM
mycrx7's Avatar
my friend had a fmu when he bought his hatch back, it was a b16a3 turbo in a ef hatchy, it went fine with the fmu and all, but he drove it like this before a week, and we all got him to get it tuned with crome, the damage was already done and in less then 3 days with a socketed ecu and tuned with a wb all 4 ringlands were owned. id rather use a vafc then a fmu, but xenocron does ecus for cheap as hell, hit me up if u need any obd1 socketed ecu my friend in seattle has some socketed and burned by him.
Old Jan 6, 2006 | 07:28 AM
BottleFED91CRXSI's Avatar
at least get a set of dsm 450 injectors w/ at least an afc
Old Jan 6, 2006 | 08:48 AM
BiG Chris's Avatar
im stuck with obd0 and safc and a fmu but i do have bigger injectors
Old Jan 6, 2006 | 09:46 AM
burnt_rice's Avatar
fmu were designed for the use with your stock assembly injectors .....not really for use with the larger injectors sizes although you would make more power by throwing them on you leave yourself the probability of detonation it all depends on what fmu ratio you are running. I was running a 12:1 vortech fmu on my sohc turbo and it ran completely fine and made desent power for just about 6-7 lbs of boost with my stock d16a6 injectors
stockb18c
Oct 24, 2006 04:55 PM
Tdawg1030
Jun 17, 2005 10:58 PM
sneezyh22a4
Nov 29, 2004 11:55 PM
GSRBoy
Nov 3, 2003 01:53 PM
M-EJ1
Feb 14, 2003 11:34 PM
