Two problems with my hatch, one thread!
Old Jan 4, 2006 | 02:36 PM
.Manny.'s Avatar
Touching My Member
Default Two problems with my hatch, one thread!
Hey everyone I have two problems with my car but before all that,
1990 Si Hatch, Dohc ZC swap.
1) Temp gauge doesnt work even after i connected the plug to the head. So engine is running off a fluidyne radiator and a FAL fan that is running from the ignition. Can't take it up to 7200 redline because of this. Goes to about 6800. How can i fix this??
2) Today i changed out the fuel filter and pumped in clean nw 91 octane with techron, took off aem short ram and replaced with stock unit. Now the motor will hesitate and it wont even rev to 6800. It will cut out at 5800 or 6k. What could be causing this?
*** One more thing, the o2 sensor is fouled out so i disconnected it. What kind of o2 sensor would i need to replace it with? Stock civic or ???
Old Jan 4, 2006 | 02:42 PM
.Manny.'s Avatar
Touching My Member
bump
Old Jan 4, 2006 | 02:58 PM
.Manny.'s Avatar
Touching My Member
ttt
Old Jan 4, 2006 | 03:10 PM
Rukusmasta2's Avatar
Default Re: (90_EF_Si)
the o2 has to be for the motor i think...i like ur avatar can u send me a bigger pic of that or waht @hotmail ...BUMP
Old Jan 4, 2006 | 03:26 PM
.Manny.'s Avatar
Touching My Member
bump..btw i just stole it off someone else bro. this is as big as it gets.
Old Jan 4, 2006 | 03:32 PM
thapimpfromchi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">bump..btw i just stole it off someone else bro. this is as big as it gets.</TD></TR></TABLE>
thief!
anyways, i would try checking ur gauge. I had a zc and a fluidyne and mine worked fine. i had a stock fan though, but i doubt the problem is that. as for the fuel filter, swap it back. if it goes back to normal, then see if u can exchange the new one for another one. faulty stuff does occasionally roll off the assembly line. o2 sensor? i used a bosch universal one for hondas. worked fine.
Old Jan 4, 2006 | 03:36 PM
.Manny.'s Avatar
Touching My Member
Default Re: (thapimpfromchi)
yeah i thought it washilarious so i had to have it. Sorry
thanks for the input man, how much was the sensor??
yeah im going to check it to see whats up with it.
thanks again.
any more input would and will be greatly aprreciated.
Old Jan 4, 2006 | 04:11 PM
i dont remember how much i paid for it. i got it from autozone. i dont think i paid more than 10 bucks for it. good luck with ur car.
Old Jan 4, 2006 | 04:27 PM
.Manny.'s Avatar
Touching My Member
checked the ecu and got codes 7 and 9
Old Jan 4, 2006 | 04:35 PM
md88hfcrx's Avatar
$17 for one you have to extend your own wire...like $60 pre wired. both the same $17
Old Jan 4, 2006 | 05:36 PM
what kinda ecu r u running? a JDM zc ecu or a usdm da ecu
Old Jan 4, 2006 | 05:58 PM
SiR Inspired ED7's Avatar
Default Re: (Rukusmasta2)
Old Jan 4, 2006 | 06:04 PM
pandarex's Avatar
Default Re: Two problems with my hatch, one thread! (90_EF_Si)
i think there some sort of temp something on the stock fans, ty putting a stock fan back on and see
Old Jan 4, 2006 | 07:06 PM
.Manny.'s Avatar
Touching My Member
Default Re: Two problems with my hatch, one thread! (hondazc89)
ive got a PG7 ecu. Its the us integra ecu. I just switched the tps sensor with one i had and back again beause the car would start and then die out. what can i do?
Old Jan 5, 2006 | 06:07 AM
paopao's Avatar
Get a manual. Lots of these problems are covered in the trouble shooting section.
Old Jan 5, 2006 | 07:14 AM
1point7db2's Avatar
Default Re: Two problems with my hatch, one thread! (paopao)
Where can I get that shirt?
Old Jan 5, 2006 | 10:22 AM
Default Re: Two problems with my hatch, one thread! (blownEG93)
thast what im sayin
Old Jan 5, 2006 | 10:23 AM
JDMCivicEF9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">
Hey I want a shirt like that! Where can I get one?
Old Jan 5, 2006 | 11:41 AM
Default Re: Two problems with my hatch, one thread! (JDMCivicEF9)
any luck with the car?
Old Jan 5, 2006 | 08:00 PM
.Manny.'s Avatar
Touching My Member
hey guys, update: timing was actually off by like 3 teeth all together, i fixed that and it is dead on now. still have to get the timing gun and check it out one more time.
Still having a problem, now im running way too rich. my spark plugs got fouled out. they are dark as hell.
i put in a bosch o2 sensor and check engine light is not on anymore.
what else could be causing it to run so rich?
remember Dohc Zc, 8mm Accel wires and had to buy some crappy Denso plugs. gap is at 44.
the fumes were so strong it made my head hurt. Any help is appreciated.
Old Jan 5, 2006 | 10:32 PM
gapped at 44? i had mine gapped at 35ish. mine ran perfect. when u said ur timing was off, was it retarded or advanced? im gonna guess retarded cuz u lost power.
Old Jan 6, 2006 | 09:04 AM
.Manny.'s Avatar
Touching My Member
35? i was told it had to be at 44. i'll try it anyway. Its is running really rich, it already fouled the denso's and i just put them on last night.
It wont rev past 5k, it stutters really badly too.
it was running fine until i changed the fuel filter and pumped in 91. f-ing techron! jk
Old Jan 6, 2006 | 11:43 AM
.Manny.'s Avatar
Touching My Member
bump
Old Jan 6, 2006 | 12:03 PM
CBURKE's Avatar
Have you checked your injectors? Sounds like you may be just pushing fuel through. I would also check you fuel pump too. Also check for any leaks under the new fuel filter and around the injectors.
Old Jan 9, 2006 | 06:01 AM
Default Re: (CBURKE)
any updates?
sstupid
15
Aug 11, 2012 06:27 PM
VTDr0p0ut
Mar 1, 2008 05:37 PM
awalp
Oct 24, 2007 07:41 PM
erickusdmb16
Jun 29, 2004 07:11 AM
5 Skware
Sep 12, 2003 07:05 PM
