oil in spark plugs/headgasket???
Old Jan 4, 2006 | 02:09 PM
EF9 JAMS!!!'s Avatar
Default oil in spark plugs/headgasket???
so i have recently just been doing some basic tune ups....oil change air filter blah blah blah...and i was about to take out my spark plugs and noticed that there was some oil around the inside. i have just a std motor....(no big deal...just a daily driver.) and it just hit 200,000 miles like a week ago...the thing is it runs really good still. no unfamiliar sounds or anything.....i do believe i "might" have a blown head gasket....i am not sure why there is oil around the inside but if someone can help me out. please do so...also if it is or is not a blown head gasket....either or...how do i go about fixing this...how much..parts...
Old Jan 4, 2006 | 02:15 PM
Riceburner247's Avatar
Default Re: oil in spark plugs/headgasket??? (hatch91JDM)
If you had a blown headgasket, the oil would be a greyish color. You'll also see white smoke when you start it up in the morning.
The oil you're seeing could be due to the 200,000 mile mark. Could be worn rings or seals. Either way, if you aren't noticing anything bad in performance, I wouldn't worry about it. Just change your fluids and do tune-ups, you should be fine. Does your car smoke at all? What color, if so?
Old Jan 4, 2006 | 02:21 PM
crxnj's Avatar
Default Re: oil in spark plugs/headgasket??? (Riceburner247)
That was happening to me ..So I changed the o-rings and valve cover gasket and it cured the problem..It got so bad the car wouldn't even start sometimes without taking out the plugs and soaking it up with a paper towel..
Old Jan 4, 2006 | 02:46 PM
ProjectDarkBlack's Avatar
Default Re: oil in spark plugs/headgasket??? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">That was happening to me ..So I changed the o-rings and valve cover gasket and it cured the problem..It got so bad the car wouldn't even start sometimes without taking out the plugs and soaking it up with a paper towel..</TD></TR></TABLE>
Old Jan 4, 2006 | 03:09 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: oil in spark plugs/headgasket??? (ProjectDarkBlack)
I had the same problem and replaced the o-rings and it fixed it for the most part. I think that my vc surface isnt true though thats why its still leaking a little.
Old Jan 4, 2006 | 10:31 PM
mckim's Avatar
it's defective O-ring. My car usuallyy have oil in spark plug and spark plug
wire. I know it's a leaking oil from a defective one of O-ring. Not really
big problem.
Old Jan 4, 2006 | 10:43 PM
killa rex's Avatar
get a new valve cover gasket kit..it will have the spark plug seals, grommets, and valve cover gasket
Old Jan 5, 2006 | 11:32 AM
Default Re: oil in spark plugs/headgasket??? (xmunxjai648)
thanks for the fyi...it really helped.
Old Jan 5, 2006 | 12:43 PM
barely4dr's Avatar
Ho much would it be to fix a blown head gasket?.....I have white smoke on startup, and I think some grey-colored oil.
Damn I'm scared, iono if I can afford this [college student money sucks]
Ej2-93dxer
May 12, 2010 02:36 PM
CRXDaddy78155
11
Feb 19, 2007 01:03 PM
hbomb90
Apr 11, 2004 07:39 PM
VtecDA9
Apr 5, 2004 11:17 AM
Digital-R
Aug 3, 2001 11:07 AM
