after b16 swap found plug?
Not you again, lol, anyways if its the plug i think it is, then NO u dont need it. Just let it hang or whatever. It appears to have been for that sensor only found on 88-91 Si's on the back of the intake manifold. Its not important.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badboypolar2 »</TD></TR><TR><TD CLASS="quote">that looks like the coolant temp sensor. </TD></TR></TABLE>
Coolant temp? There's only 2 on the D and B series blocks, and that looks like neither.
What are the colors of the wires on that plug?
I know I didn't use the same exact plug on my B16 swap and if I remember right it was something to do with the fast idle valve on the D16.
haha ERIC!
yeah see i dont think its needed.. becz the car runs fine and no CEL's.
i need to get you some pix and show you the engine you put in over h-t...lol
besides we ran into another problem, the y1 lsd tranny is being a bitch. it wont stay in 5th gear, so that cant be a good thing. we're not sure if its just that the shifter is to short and wont let the gear go all the way in (all gears dont feel like they go in, but 5th is the only one that pops back out)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr »</TD></TR><TR><TD CLASS="quote">
besides we ran into another problem, the y1 lsd tranny is being a bitch. it wont stay in 5th gear, so that cant be a good thing. we're not sure if its just that the shifter is to short and wont let the gear go all the way in (all gears dont feel like they go in, but 5th is the only one that pops back out)</TD></TR></TABLE>
I have the same problem with my second gear and it's the synchro. It ohnly pops out when I'm going right
First check all your mounts/shift linkage and make sure there tight.
What half shaft do you have?
that is for the purge solenoid which is not on that motor... i had the same problem when i swapped my z6 in and i called rywire up... ive ran my motor like that without any problems for almost a year now... i just let it hang
-Josh
-Josh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crimson_Tide »</TD></TR><TR><TD CLASS="quote">that is for the purge solenoid which is not on that motor... i had the same problem when i swapped my z6 in and i called rywire up... ive ran my motor like that without any problems for almost a year now... i just let it hang
-Josh</TD></TR></TABLE>
that's why I asked what colors they were. I posted this a long time ago when I was first doing my swap
D16 Dashpot Control Solenoid
B16 Sugre cut-Off Solenoid
If your not sure the dashpot is vacuum operated, it is design to keep the throttle plate from closing suddenly when you decelerate. its more of an emissions improvement device then anything. it allows more air to mix in with the extra fuel/gas during decel
Hope that helps.
Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95gsr »</TD></TR><TR><TD CLASS="quote">haha ERIC!
HAHAH fo sho man.
HAHAH fo sho man.
<font size="5" ERIC THIS IS FOR YOU!</font>
well it took a while to get a pic, but theres the beauty u installed over H-T.. Thanks!
[img=http://img86.imageshack.us/img86/2918/zane18qm.th.jpg]
Check your tranny fluid first, that will cause your problem if it is not full enough. If it is full enough then the damgage is done and you need to crack the tranny open before more problems arise.
My buddy had the same problem (popping out of 5th)but he did not run it too long w/o fluid, filled it up and has not had a problem since. 5th gear is the first to go when low on fluid because of it's placement in the tranny.
iversonaintnutin
May 13, 2008 12:51 PM
prettylew
Oct 16, 2007 09:05 AM
