Compression check on a H22a?
Old Jan 4, 2006 | 11:25 AM
r1de4life's Avatar
Default Compression check on a H22a?
When you do a compression check on a H22A motor what should the compression gauge say and how many times do you crank it?
Old Jan 4, 2006 | 11:28 AM
prelittlelude's Avatar
Default Re: Compression check on a H22a? (r1de4life)
pull the fuse for the fuel pump.
hold the throttle plate open,
then crank it until the gague stops moving. thats how i do it.
depending on you elevation the numbers could vary greatly from mine to yours.. but your looking for comparability so that they would all be withink 5 to 10 psi of each other..
Old Jan 4, 2006 | 11:45 AM
r1de4life's Avatar
Default Re: Compression check on a H22a? (prelittlelude)
thanks alot dude. i appreciate it
Old Jan 4, 2006 | 12:34 PM
InvaderTrax's Avatar
Make sure you remove all your spark plugs. Don't wanna start it while you're checking compression. And try not to turn it over more then 10 seconds. And space out the checks so you don't overheat your starter. You compression should be in the neighborhood of 200 PSI, and shouldn't see more then 10 PSI difference from your highest to lowest cylinder
Old Jan 4, 2006 | 02:40 PM
Silver Surfer's Avatar
i thought a 10% difference was the rule so 20psi
i did mine a couple months ago and got 220 220 220 200, 4 3 2 1 respectively
Old Jan 4, 2006 | 05:03 PM
r1de4life's Avatar
Default Re: (Silver Surfer)
so is tht good compresion on yours?
Old Jan 4, 2006 | 05:13 PM
SHluder's Avatar
Default Re: (r1de4life)
http://www.superhonda.com/foru...71701
Good How-To for checking your compression.
Old Jan 4, 2006 | 05:38 PM
r1de4life's Avatar
Default Re: (SHluder)
yea
BB1 H22A LUDE
Jan 12, 2008 07:44 PM
JasonST
Jun 8, 2007 11:38 PM
Sproket
May 22, 2006 08:15 PM
ItalynStylion
Aug 4, 2004 12:59 PM
chinhead1228
Jun 17, 2003 05:51 PM
