can a +40 offset fit?
Old Jan 4, 2006 | 06:13 AM
wytiak3's Avatar
Default can a +40 offset fit?
i got a 94 ex. Can i fit in a 4x6x100 with +40 offset?
Old Jan 4, 2006 | 06:16 AM
ekcivic9's Avatar
4 x 6 x 100?
Old Jan 4, 2006 | 07:01 AM
I3ooS710's Avatar
Default Re: (ekcivic9)
Are you talking about your wheel being ?? x 6 because I don't understand the 4x6x100. Regardless, it will fit w/o any problems. But that's only assuming your wheel is ?? x 6 with a 4x100 lug pattern on a +40 offset.
Old Jan 4, 2006 | 07:02 AM
Slow EJ8's Avatar
Default Re: (I3ooS710)
Maybe he meant 14x6 w/ 4x100 lug pattern and +40 offset? I dunno just a guess.
Old Jan 4, 2006 | 07:08 AM
I3ooS710's Avatar
Default Re: (Slow EJ8)
That's what I'm guessing.
Old Jan 4, 2006 | 09:14 AM
wytiak3's Avatar
yeah. 14 inch diameter, 6 inch wide, 4x100 lug pattern, +40 offset.
Are the wheels going to stick out a little nicely or go further inside the wheel well kinda ugly, compared to the original 14 inch steelies with 4x100 lug pattern, 5.5 inch wide (don't know the offset)?
Modified by wytiak3 at 6:43 PM 1/4/2006
Old Jan 4, 2006 | 09:47 AM
UberMunkey's Avatar
higher numerical offset moves the wheel closer to the center of the car, but it is also reletive to the wheel's width. so depending on what offset your steelies were, the new wheels may or may not stick out a little farther because they are 1/2 an inch wider. more than likely, they will be about the same.
Mr Ohms
Jan 15, 2013 04:01 PM
ThatOneOG
Oct 4, 2009 06:58 PM
honda_andy
Jun 26, 2006 05:22 AM
poweredbyhonda604
Jan 25, 2003 07:46 PM
RacerBoy
Dec 9, 2002 04:43 AM
