K20 Wonders...
Old Jan 3, 2006 | 08:16 PM
HondaTom's Avatar
Default K20 Wonders...
Im almost positive that this has been covered, I did search and couldnt find anything, so... I didnt know whether this topic was better suited for here, or tech/misc, but anyway. What are the differences in the K20Z1, from the K20A2?
Old Jan 3, 2006 | 08:35 PM
initialse7en's Avatar
Default Re: K20 Wonders... (HondaTom)
from what i hear, practically nothing
but i may be wrong
Old Jan 4, 2006 | 07:20 AM
Slow EJ8's Avatar
Only think I can think of now is the cams. Drawing a blank other than that. ECU I guess its sorta part of the motor. Final Drive on tranny.... I know this isnt technically the motor but arg I cant think of any more.
Old Jan 4, 2006 | 11:27 AM
KOREAN's Avatar
Default Re: K20 Wonders... (Slow EJ8)
drive by wire?
Old Jan 4, 2006 | 12:25 PM
Slow EJ8's Avatar
Default Re: K20 Wonders... (jpjdmsi)
Do not thread hijack and take it to the classifieds.
Reported
Old Jan 4, 2006 | 02:07 PM
Turn or Burn's Avatar
The k20z1 has type-r cams.
Old Jan 4, 2006 | 02:33 PM
130R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by korean &raquo;</TD></TR><TR><TD CLASS="quote">drive by wire?</TD></TR></TABLE>
k20a3 / k20z1 are both drive by wire. maybe you mistake it for the k20z3
cams and intake manifold are from the itr
also the mounts for the k20z1 tranny are different
the ecu is different s well.
Old Jan 4, 2006 | 05:22 PM
BoostedEMone's Avatar
Default Re: K20 Wonders... (carbing'ed)
the k20z has like.. 3 less hp from some type of noise reducing thing they added to the motor...
Old Jan 4, 2006 | 05:23 PM
130R's Avatar
Default Re: K20 Wonders... (BoostedEMone)
you are wrong.
Old Jan 4, 2006 | 06:32 PM
HondaTom's Avatar
So, just so that we are on the same page, the 05-06 Type-S's have the K20Z1 right?
Old Jan 4, 2006 | 07:10 PM
Slow EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaTom &raquo;</TD></TR><TR><TD CLASS="quote">So, just so that we are on the same page, the 05-06 Type-S's have the K20Z1 right?</TD></TR></TABLE>
yes
Old Jan 5, 2006 | 06:53 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed &raquo;</TD></TR><TR><TD CLASS="quote">
the ecu is different s well.</TD></TR></TABLE>
I think you have a typo.
The K20Z3 (2006 Civic Si) has drive-by-wire throttle control. It's electronic.
The only other motor that has DBW is the K24 from the Acura TSX.
The K20Z1 does not have Drive-By-Wire. It has a conventional, physical throttle cable linkage.
Old Jan 5, 2006 | 07:33 AM
MissRSX-S's Avatar
eitherway its 10horses difference. its said to have the itr cams, final drive, and lsd. but from what i understand the itr lsd has yet to be found in one
Old Jan 5, 2006 | 09:29 AM
D-Rob's Avatar
Default Re: (MissRSX-S)
The K20Z3 has an LSD.
Not the K20Z1.
Old Jan 5, 2006 | 04:51 PM
130R's Avatar
Default Re: K20 Wonders... (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
The K20Z1 does not have Drive-By-Wire. It has a conventional, physical throttle cable linkage.</TD></TR></TABLE>
k20a2 / k20z1 are both drive by wire</TD></TR></TABLE>
fixed
Old Jan 5, 2006 | 05:27 PM
Revolution2zz's Avatar
Damn everybody is wrong in here.
02-04 RSX-S has the K20A2
05-06 RSX-S has the K20Z1
06+ Civic has K20Z3 (the only K20 with electronic drive by wire)
the question is the difference between the K20A2 and K20Z1 (02-04 RSX-S engine and 05-06 RSX-S engine)
Pretty much identical except the K20Z1(05+RSX-S) has Type R cams, Type R intake snorkel, slightly bigger throttle body, high flow cat, Type R 4.77 Final Drive, (some say ITR intake manifold also but part number is still a PRB part), different (newer, faster ECU), Type R flywheel, slightly different wiring harness, primary 02 sensor is wired differently. I also heard the K20Z1 is cast from a lighter, stronger aluminum..but not confirmed. The mounts on the transmission is lighly different and it adds a dynamic engine damper mount.
Basically its a K20A2 with a whole bunch of Type R upgraded parts.
for 05 the K20Z1 is rated at 210hp, for 06 with the new SAE standard its now rated at 201. If the K20A2 were rated the same way the 06's are, it would probably be advertise as having 192hp instead of 200.
Old Jan 5, 2006 | 11:44 PM
130R's Avatar
Default Re: K20 Wonders... (Revolution2zz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolution2zz &raquo;</TD></TR><TR><TD CLASS="quote">Damn everybody is wrong in here.
im right. i typed 3 instead of 2
Old Jan 6, 2006 | 03:15 AM
HondaTom's Avatar
Cool, thanks alot guys.
Old Jan 6, 2006 | 11:05 AM
norcalcrx's Avatar
Err the k24 from the tsx also has drive by wire.
Old Jan 6, 2006 | 11:32 AM
D-Rob's Avatar
Default Re: K20 Wonders... (norcalcrx)
... I already mentioned that.
Old Jan 6, 2006 | 02:08 PM
norcalcrx's Avatar
lol must have missed that...what he said then.
Old Jan 8, 2006 | 08:38 PM
Mike04Civic's Avatar
wait,..so which car has the K20a2? is that the type-s engines prior to 05?
nevermind...missed Revolution2zz's post....
Old Jan 9, 2006 | 05:43 PM
02ep3's Avatar
Default Re: K20 Wonders... (Mike04Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike04Civic &raquo;</TD></TR><TR><TD CLASS="quote">
wait,..so which car has the K20a2? is that the type-s engines prior to 05? </TD></TR></TABLE>
Old Jan 11, 2006 | 06:14 PM
Ghostofwar's Avatar
Good info! I dont even think I have seen this much info in the differences on ClubRSX.com. Maybe its because I just didnt search.
Old Jan 11, 2006 | 10:57 PM
Nov!ce's Avatar
Thank you for clearing all of that up. I was beginning to wonder.
