Wheel spec for EG
Old Jan 3, 2006 | 06:43 PM
LazJDM's Avatar
Default Wheel spec for EG
will 15by6.5 4by100 +40 offset fit a 93 cx EG? and what tire size is best.
Old Jan 3, 2006 | 06:51 PM
Targa250R's Avatar
be professional
Default Re: Wheel spec for EG (LazJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LazJDM &raquo;</TD></TR><TR><TD CLASS="quote">will 15by6.5 4by100 +40 offset fit a 93 cx EG?</TD></TR></TABLE>
Yes, as long as the hub bore is big enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and what tire size is best.</TD></TR></TABLE>
195/50-15 is closest to the stock overall diameter. 205/50-15 will also work okay.
Old Jan 3, 2006 | 07:47 PM
waddy41's Avatar
u might rub with +40 offset..
try +42.....
Old Jan 3, 2006 | 10:37 PM
LazJDM's Avatar
Default Re: (waddy41)
not sure but the rims im talking about are the Rota X model (SSR rep)i think they fit EG's not sure.there black with red lip
Old Jan 4, 2006 | 12:13 AM
DRAMA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 &raquo;</TD></TR><TR><TD CLASS="quote">u might rub with +40 offset..
try +42.....</TD></TR></TABLE>
on an EG, you'll be fine with 40, even 38 (my old volks). if you go down to 35, then you run into rubbing problems if your car is lowered.
Old Jan 4, 2006 | 12:27 AM
fms1day's Avatar
Default Re: Wheel spec for EG (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
205/50-15 will also work okay.</TD></TR></TABLE>
running on this currently... on my cx hatch...
Old Jan 4, 2006 | 12:34 AM
littleredcivic's Avatar
Default Re: Wheel spec for EG (fms1day)
tire profiles also make a difference when choosing a tire to mount on your new wheels. the closest size to stock will depend on your trim level... a 175/70r13 is a bit different than if you have a 185/60r14...anything like 195/50r15, 195/55r15, or 205/50r15 in most tire models will be just find unless the car is super slammed.
GraphiteMW
11
Feb 19, 2007 06:06 PM
Kapetan
10
Jun 8, 2006 09:45 AM
BUKKAKE-ADAM
Jul 11, 2005 01:26 PM
fastwanabe
Jan 13, 2005 01:12 PM
IloveAPC
Nov 30, 2004 09:52 PM
