ECU code problems
Old Jan 3, 2006 | 04:01 PM
ozzyman's Avatar
Default ECU code problems
Okay so this is an EF that I just put another DX motor in, because the old one blew up. Its popping a CEL but the light on the ECU isnt blinking properly. Its giving me ALL short blinks... and if I add them up I get a code 6, 7, 10, 16. Thats right 10 short blinks and 16 short blinks... I dont get it. I change out the PM5 ECU with a known good PM5 ECU and now the only codes I get at 6 and 10, but still gives me 10 short blinks. Is this normal?? Im lost right now.....
Old Jan 3, 2006 | 04:15 PM
ozzyman's Avatar
Default Re: ECU code problems (ozzyman)
Anyone?
Old Jan 3, 2006 | 05:25 PM
Mach69's Avatar
OBD-0 cars dont have long blinks, sorry? You will have to count them consecutively until you get a long pause. I would try and fix the codes the good known ecu gave you, 10 and 6.
This should help you out: https://honda-tech.com/zerothread?id=468260
Old Jan 3, 2006 | 05:27 PM
ozzyman's Avatar
Default Re: ECU code problems (Mach69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 &raquo;</TD></TR><TR><TD CLASS="quote">OBD-0 cars dont have long blinks, sorry? You will have to count them consecutively until you get a long pause. I would try and fix the codes the good known ecu gave you, 10 and 6.
This should help you out: https://honda-tech.com/zerothread?id=468260</TD></TR></TABLE>
Perfect. Thats all I wanted to know. I read on a hybrid forum that even 88+ have long/short blinks but I guess its just misinformation.
Thanks!
Wanza
Jul 7, 2018 08:02 AM
nicknack25
26
Dec 16, 2010 04:30 AM
F22B1Prelude
Nov 6, 2008 12:27 PM
civicracer94
Dec 8, 2006 06:22 PM
JapJunkie
Sep 22, 2004 06:35 PM
