ECU codes - OBD1 - searched
Old Jan 3, 2006 | 03:34 PM
Daniel-sanB1's Avatar
Default ECU codes - OBD1 - searched
I'm throwing a code and my car is jerking above 3k rpm
I'm pretty sure it's a fuel issue.
but I can't get the code.
I read the how too get the ECU code, and looked at my wires, could find it, then searched again and finally realised it's the only plug with 2 wires. in my case it was a Brown plug with a think blue wire and regular size black wire.
anyways, I put my wire in, like they said to short it out. and nothing happened. I turned my key to the ON position on the ignition, all my cluster lights turned on, and stayed on, my engine light just stays on.
I tried 3 times putting the wire in, and it's in properly
even tried putting the wire on the other end of the harness (the male side) and I saw some sparks.. to definitely wrong wires.
anyways, please help
what am I doing wrong ?
Old Jan 3, 2006 | 03:35 PM
A.E Motoring's Avatar
Default Re: ECU codes - OBD1 - searched (Daniel-sanB1)
look at the very top of the page
Old Jan 3, 2006 | 03:38 PM
CRXified's Avatar
https://honda-tech.com/zerothread?id=1171263
incase u dont wanna make the extra click
Old Jan 3, 2006 | 03:56 PM
pdiggitydogg's Avatar
possible that the wire youre using sucks...try a prong spade connector (really, thats probably not the correct terminology)
Old Jan 3, 2006 | 06:24 PM
CRXified's Avatar
Default Re: (pdiggitydogg)
haha i used a paperclip straightened out and it worked
Old Jan 4, 2006 | 01:38 PM
Default Re: (CRXified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel-sanB1 &raquo;</TD></TR><TR><TD CLASS="quote"> read the how too get the ECU code</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEJ &raquo;</TD></TR><TR><TD CLASS="quote"> look at the very top of the page </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1171263
incase u dont wanna make the extra click </TD></TR></TABLE>
thanks guys, but I read it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel-sanB1 &raquo;</TD></TR><TR><TD CLASS="quote"> even tried putting the wire on the other end of the harness (the male side) and I saw some sparks.. to definitely wrong wires.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote"> possible that the wire youre using sucks...try a prong spade connector (really, thats probably not the correct terminology)
nope, my wire definitely works
anybody else ??
my engine light just stays ON, Plese help me !
Old Jan 4, 2006 | 01:45 PM
mwieczorek43's Avatar
Default Re: (Daniel-sanB1)
Does it flash once really long and repeats or... just stays on?
You're sure you're in the right plug? Mine was sharing a little green sleeve thingy with another fat plug next to it.... if that helps?
Did you see there's a video in that thread as-well telling you step by step.
Old Jan 4, 2006 | 03:07 PM
Default Re: (mwieczorek43)
ya.. I have no sound on this computer, but the video is SUPER useless
first off, the dash is off, and the plug is already out
he shows you how to put a wire in 2 prongs.
ya.. that helps.
my wires are SUPER tight and it's a bitch to move em, plus it's ******* -40 outside
is there more then 1 plug that only has 2 wires ?
this is the only one I could find.
and I had to detach it from the white plug (they were attached together)
and also, I had to unplug to 2 end (female to male)
the picture/video show the wire alone, with no other end.
maybe I'm looking at the wrong wire all together.
Old Jan 4, 2006 | 03:08 PM
and no, it dones't flash.
it just stays on with all my other lights on the clsuter when the car isn't "turned on"
lol that souded weird
Old Jan 5, 2006 | 09:01 AM
http://www.hstuners.com/forums...23007
I dont remember if the one here has images showing the connector or not...so maybe check mine out (it doesnt matter that its obd2, the process is identical)
if the light just turns on without flashing, its not jumping correctly
Old Jan 5, 2006 | 10:10 PM
thank you man!!
wow, I guess no one has ever done this to my civic. the plug still had original clips holding it real high. that green boot was STUCK.
my first 2 civic were very obvious
thanks again
code15 & 16
JDMlyfestyle
588
Nov 3, 2022 12:37 PM
JDMlyfestyle
18
Apr 29, 2021 01:09 AM
mizle
Jul 11, 2012 09:07 PM
noender
Dec 5, 2010 12:08 PM
b18c4dr
Mar 1, 2006 03:09 PM
