500 whp fuel setup's
curious to see what you guys are running. im shooting for 400-450 whp and i would like to see what you guys are currently using or what will support those numbers. i was thinking just a walboro 255 hp with some 700cc injectors. would that be suitable for that amount of power? TIA
also would the stock ignition be okay for the amount of power? should i upgrade my coil and get like an msd 6al or digital 6 or something of that nature
You got it pretty correct.
Stock everything, just a pump and injectors.
When you buy the injectors, if the price difference isnt too big just go for the 1000cc injectors in case you ever decide to up the boost.
Stock ignition is fine until you have a problem with spark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">do a quick search in the FI forum archived content for 500whp and 500hp and you'll find more info than you'll ever need.</TD></TR></TABLE>
i thought you were being an ***, till i searched the archives
, thanks
, thanks
i'm running close to 700 whp i'm using 2 Aeromotive A1000 Pumps, Fuel Sump,
-10 Fuel Lines, 1600 cc injectors. And for Ignition i'm using CDI, with Coil on plugs. A little bit overkill but i'm happy with the set up
KStuned
Jan 3, 2003 04:23 AM
