What is your prefered method of welding a manifold?...
Old Jan 3, 2006 | 12:09 PM
*Boostwerks*'s Avatar
Default What is your prefered method of welding a manifold?...
Do you...
1. Tack the entire manifold together, and then complete the welds.
or
2. Weld the manifold peice by peice.
I would think that it would be easier to say weld up the collector completely, and then tack the rest of the manifold. But from the looks of some manifolds on here, I have no idea how you could tack it all, and then weld.
TIA,
Bryson
Old Jan 3, 2006 | 12:13 PM
Race Egr's Avatar
Default Re: What is your prefered method of welding a manifold?... (Bryson)
Im not really sure ,but I would guess weld the collector up seprate then tack it all up break each runner off weld ( not all the tacks) then weld all the runners together then weld the runners to the headflange and collector. Im wondering how u weld the runners to the collector it looks like a pain in the but gettin the torch to fit in between them
Old Jan 3, 2006 | 12:36 PM
Default Re: What is your prefered method of welding a manifold?... (super-NAPIER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-NAPIER &raquo;</TD></TR><TR><TD CLASS="quote">Im not really sure ,but I would guess weld the collector up seprate then tack it all up break each runner off weld ( not all the tacks) then weld all the runners together then weld the runners to the headflange and collector. Im wondering how u weld the runners to the collector it looks like a pain in the but gettin the torch to fit in between them
Thats exactly what I'm wondering.
Old Jan 3, 2006 | 12:40 PM
Ekasey's Avatar
Ideally
Tack everything togther
Break tacks on flnage and collector if needed (we use a slip fit 99% of the time)
Weld tubes individually
Fit tubes back into fixture
Refit tubes because they tend to pull when welding
Weld tubes to head flange
Re fit tubes once more and then weld collector on (we skip the welding in this step)
Old Jan 3, 2006 | 12:48 PM
beepy's Avatar
Default Re: What is your prefered method of welding a manifold?... (Casey@Burns)
It may just be my **** ME background, but I make a manufacturing process plan for each one.
Old Jan 3, 2006 | 01:44 PM
Rtype16's Avatar
Default Re: What is your prefered method of welding a manifold?... (beepy)
I do exactly what casey said.
Old Jan 3, 2006 | 07:11 PM
Enzo-Racing's Avatar
Default Re: What is your prefered method of welding a manifold?... (Rtype16)
Casey summed it all up...
Old Jan 4, 2006 | 10:54 AM
Awsome. Thanks guys...
Old Jan 4, 2006 | 01:46 PM
Pay2play killa's Avatar
Default Re: (Bryson)
i lucked out when i mig'd my ram-horn. I tacked it all together and welded it as one big piece. Didnt have to break the tacks on the collector or flange but I was prepared to
TravisBiggie
Sep 6, 2013 07:39 AM
jbell
Feb 6, 2006 01:12 PM
Fatty_1775
Aug 17, 2005 05:33 AM
MugenFlaredCRX
May 26, 2005 12:08 AM
pissedoffsol
Jun 13, 2003 11:06 AM
