questions about jdm d15 and d16
i hav a jdm sohc zc swap, ima about to do a mini me on it and was just wondering, the head ima going to buy is the d16z6 head with no camshaft, will a jdm d15 vtec cam shaft fit on that head, if any body knows let me know
Modified by kantfadedisazn at 11:41 AM 1/3/2006
Yeah it fits and its actually more aggresive then the stock z6 cam anyway..Just make sure you have the right d15b vtec motor because there was 3 stage vtec version also of the d15b vtec..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Yeah it fits and its actually more aggresive then the stock z6 cam anyway..Just make sure you have the right d15b vtec motor because there was 3 stage vtec version also of the d15b vtec..</TD></TR></TABLE>
i c so the jdm d15b vtec camshaft fits the z6 head, ima hav to do that then but will all the d15b vtec cams fit even the one with the 3 stage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kantfadedisazn »</TD></TR><TR><TD CLASS="quote">
Im not %100 sure if the 3 stage vtec cam will work with the z6 head..I dont think so though because that motor is weierd..How it sounds it has 3 different cam profiles..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g »</TD></TR><TR><TD CLASS="quote">
The 3-stage VTEC engine runs in 12-valve mode up to around 3000rpm. In this range, running in ideal conditions will activate the 'lean-burn' mode, where air-fuel ratios as high as 20:1 can be used to take advantage of the intake swirl induced by the 12-valve operation. This lean-burn mode is what makes the 30km/l mileage (for constant 60kmh speed) possible. A green 'ECONO' LED lights up on the dash when lean-burn mode is engaged.
From around 3000rpm up to about 6000rpm, the first VTEC actuator switch engages and the previously inactive intake valve now goes into operation. The engine now runs in 16-valve mode behaves just like any of Honda's highly spec'ed 16valve PGM-Fi engines. After 6000rpm the second VTEC actuator switch engages the wild cam/rocker arm pair for the intake valves. This switches the engine into the wild-cam mode where it goes bonkers delivering 130ps at 7000rpm. With the proper driving style, one can actually enjoy mileage as high as 16 or 18km/l in town driving while at the same time frequently indulging in VTEC-inspired sprints to overtake slower vehicles.
</TD></TR></TABLE>Im not %100 sure if the 3 stage vtec cam will work with the z6 head..I dont think so though because that motor is weierd..How it sounds it has 3 different cam profiles..
i just asked my friend he said it would work and the JDM SOHC D15B7 is 2 stage not 3 stage
UndergroundTuning
33
Dec 12, 2021 08:33 AM
JamesV
11
Dec 29, 2005 11:57 AM
