HELP NEEDED SOON
Old Jan 3, 2006 | 09:33 AM
jdmsoljah's Avatar
Default HELP NEEDED SOON
help me please and tell me what to do peeps okay here the problem only on my drivers side is the headlight out on my 94 honda del sol okay but when i hit the high beams both come on so tell me what the problem and how can i fix it okay thanks H-T asap well i used to shake the back of the housing and it would come on but it doesn't come on anymore so how do i fix this problem k thanks it was working since july thanks again
Old Jan 3, 2006 | 09:46 AM
Hondaciv95VX's Avatar
Default Re: HELP NEEDED SOON (jdmsoljah)
Change both your lights.**
Make sure its tight in the back of the housing....don't shake it. Look.
Old Jan 3, 2006 | 09:48 AM
dohcVTECeg2's Avatar
Default Re: HELP NEEDED SOON (Hondaciv95VX)
yea change your bulbs. one is out thats why its not coming on
Old Jan 3, 2006 | 09:50 AM
jdmsoljah's Avatar
noo but when i turn the high lights on they come on
Old Jan 3, 2006 | 09:53 AM
Default Re: (jdmsoljah)
yea you have a high beam setting and low beam setting. your low beam is burnt out. get new bulbs and you wont have the problem anymore.
Old Jan 3, 2006 | 09:57 AM
jdmsoljah's Avatar
thanks
Old Jan 3, 2006 | 09:58 AM
jdmsoljah's Avatar
okay but also when i shook the back of the wiring it would come on the low beams
Old Jan 3, 2006 | 10:04 AM
snatch's Avatar
Then check all the wiring, make sure the connections are tight, no wires are frayed, etc.
You could try switching the 2 lights (right to left, left to right), if it works then you know it's the light. If it doesn't you know it's the wiring.
Old Jan 3, 2006 | 10:28 AM
jdmsoljah's Avatar
okay yeah it was the light bulb had a bubble on trhe side okay how much do they cost peeps i jus want the regular stock light bulb and any h4 will work
Old Jan 3, 2006 | 11:45 AM
snatch's Avatar
Go to AutoZone and see for yourself.
Somewhere around $15-$20 for a new one. Maybe a little less.
Old Jan 3, 2006 | 11:50 AM
snatch's Avatar
Default Re: (******)
Here:
http://www.partsamerica.com/Pr...set=A
andyisftw
May 14, 2010 10:55 AM
Digiti123
Aug 2, 2007 06:20 AM
mlong01
Audio / Security / Video
Jul 17, 2007 05:30 PM
4thgenx42
Oct 26, 2006 06:55 AM
