Does anyone have a list of 2000 Honda CRV ABS Codes?
My CR-V's ABS light came on and I am about to check out the codes. I was wondering if anyone has a list of the CR-V ABS Codes?
I have a list of codes for my DC2, would they be the same?
Thanks!
Thanks!
From the Helm manual:
11/13/15/17 = FR/FL/RR/RL wheel sensor (open/short to body ground/short to power)
12/14/16/18 = FR/FL/RR/RL wheel sensor/pulser (chipped pulser gear/electrical noise)
31/32/33/34/35/36/37/38 = FR-IN/FR-OUT/FL-IN/FL-OUT/RR-IN/RR-OUT/RL-IN/RL-OUT Solenoid (open/short to body ground/short to power/stuck)
51 = Motor lock
52 = Motor stuck OFF
53 = Motor stuck ON
54 = Main relay stuck OFF
61 = Ignition voltage (low voltage/high voltage)
81 = CPU
Footnote: If DTCs 11-18 (wheel sensor codes) were detected the last time the vehicle was driven, the ABS indicator will stay on until the ignition switch is turned ON (II) and the control unit confirms that the wheel sensors are OK.
Hope this helps.
51 = Motor lock
53 = Motor stuck ON
81 = CPU
Hope this helps.
99sonicbluegsr
Mar 4, 2004 06:13 AM
