cold start sensor?
Old Jan 2, 2006 | 10:56 PM
twin rex's's Avatar
Default cold start sensor?
I just bought a crx and it runs like **** until it is warmed up. the guy i bought it from said it was something like a cold start sensor? anyways if anybody knows what sensor it is and where it is located i could use the help.
Old Jan 2, 2006 | 11:02 PM
crxsi8's Avatar
my ls/vtec did something like that..any check engine light..
Old Jan 2, 2006 | 11:26 PM
ED7's Avatar
ED7
Default Re: cold start sensor? (twin rex's)
Well if the ect(engine coolant temperature) wasnt reading correctly you wouldnt be getting enough fuel at startup. It could also be the iacv(idle air control valve).
Old Jan 3, 2006 | 08:30 PM
twin rex's's Avatar
thanks ill check those and no there isn't a cel
Old Jan 3, 2006 | 08:31 PM
twin rex's's Avatar
where is the ect sensor located
Old Jan 3, 2006 | 08:32 PM
SD_Lurker's Avatar
HT White Ops
cold start sensor??? I have always wondered where that thing was located??? Jking, there is no such sensor.
Old Jan 4, 2006 | 10:15 AM
twin rex's's Avatar
Default Re: cold start sensor? (nicks_jdmstyle_ef9)
ya so if u read the symptoms of my car what is it? it seems like it is some sort of sensor because once the car is warmed up it runs fine any HELP would be appreciated
Old Jan 4, 2006 | 09:23 PM
ED7's Avatar
ED7
The ect is right under the distributor....it has 2 wires... white/red and white/green. This is for an Si and it think its the same for other models.
Old Jan 4, 2006 | 10:48 PM
HiProfile's Avatar
Default Re: cold start sensor? (ED7)
Usually if it idles at 1k when it's cold, it won't run too well. The FITV is supposed to allow extra air in that case to idle at 1.5-2k until it warms up.
Mine takes a few seconds to rev up, sounds very loppy almost like a high-duration/lift cam is in there.
PhanatNy
Jan 31, 2009 12:01 PM
xxmastermindxx
Dec 7, 2006 03:54 PM
94B18B1Teg
Dec 31, 2003 03:07 PM
