Koni Yellow Shocks ??
Old Jan 2, 2006 | 08:16 PM
Rob.'s Avatar
Default Koni Yellow Shocks ??
What's the lowest drop Koni Yellow shocks can handle ?
Cuz I am thining of getting Sprint extreme springs with Ground control Top Hats and Koni Yellow shocks.
Sprint x1000 Civic/CRX 88-91 3.25"f/3.00"r $137.99
koni Yellow shocks
Old Jan 2, 2006 | 08:20 PM
crxnj's Avatar
Default Re: Koni Yellow Shocks ?? (Rob.)
Don't those Sprint® springs have progressive rates?..If so I think even a stock shock could handle those..
Old Jan 2, 2006 | 08:27 PM
Rob.'s Avatar
Default Re: Koni Yellow Shocks ?? (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Don't those Sprint® springs have progressive rates?..If so I think even a stock shock could handle those..</TD></TR></TABLE>
buddy, 3.25" drop ? I dont think so...LoL
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. &raquo;</TD></TR><TR><TD CLASS="quote">
buddy, 3.25" drop ? I dont think so...LoL</TD></TR></TABLE>
Yeah but they have progressive rates..
Old Jan 2, 2006 | 08:32 PM
Targa250R's Avatar
be professional
With OTS Koni Sports for '88-91 Civic/CRX and the Ground Control extended-travel upper mounts, your limit becomes the point at which the upper control arms hit the body.
Old Jan 2, 2006 | 08:34 PM
Rob.'s Avatar
Default Re: Koni Yellow Shocks ?? (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">With OTS Koni Sports for '88-91 Civic/CRX and the Ground Control extended-travel upper mounts, your limit becomes the point at which the upper control arms hit the body.</TD></TR></TABLE>
what do you mean ?
Old Jan 2, 2006 | 08:35 PM
Ass$nyper's Avatar
Pirate General...YARRRR
what do you mean ?</TD></TR></TABLE>
They'll take a drop fine
Old Jan 2, 2006 | 08:37 PM
Rob.'s Avatar
Default Re: Koni Yellow Shocks ?? (Ace$nyper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ace$nyper &raquo;</TD></TR><TR><TD CLASS="quote">
They'll take a drop fine </TD></TR></TABLE>
Ok, so the koni's arent like the KYB AGX's ? cuz the AGX's wont handle anything lower than 1.5" cuz they'll blow prematurely.(warranty will void it)
Old Jan 2, 2006 | 08:39 PM
Ass$nyper's Avatar
Ok, so the koni's arent like the KYB AGX's ? cuz the AGX's wont handle anything lower than 1.5" cuz they'll blow prematurely.(warranty will void it)</TD></TR></TABLE>
No Koni will safely hold a drop
Old Jan 2, 2006 | 09:01 PM
kurinto's Avatar
With the top hats it should be fine. CRX Lee is the goto guy for questions about koni's (he works for them).
Old Jan 2, 2006 | 10:45 PM
SETI20's Avatar
Warranty's void after 2". After that you're on your own.
I've bottomed mine out plenty of times. They'll take a crapload of punishment, but there is a limit.
Old Jan 2, 2006 | 11:28 PM
ED7's Avatar
ED7
Default Re: (SETI20)
That is way too much of a drop and will only hurt performance and wear out other parts faster. Go for around 2" but you will need some more travel in the fronts still.
Old Jan 3, 2006 | 01:57 AM
RaCk's Avatar
My old koni'es blew gaskets all the time. With a 30mm drop. I hate koni'es.
Old Jan 3, 2006 | 09:31 AM
The Setup's Avatar
Targa250R? -- From SHO? --&gt; Recaro_civic_R right here from the old days.
What is the advantage to using the top hat? -- I knew knew you could do that.
Old Jan 3, 2006 | 09:34 AM
Rob.'s Avatar
Default Re: Koni Yellow Shocks ?? (The Setup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Setup &raquo;</TD></TR><TR><TD CLASS="quote">
What is the advantage to using the top hat? -- I knew knew you could do that.</TD></TR></TABLE>
Relocates shock upward 24mm to allow extra suspension travel.
http://www.ground-control-stor.../CA=5
Using on TEINS
Old Jan 3, 2006 | 09:57 AM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote"> your limit becomes the point at which the upper control arms hit the body.</TD></TR></TABLE>
Yup.
Old Jan 3, 2006 | 10:39 AM
Tyson's Avatar
Using on TEINS
is the shock body narrow enough to fit inside the top hat? doesnt look like it. if it doesnt, its not doing anything other than limiting droop. because if the shock body cant fit inside the top hat, then its just going to crash into the top hat.
Old Jan 3, 2006 | 11:52 AM
rbjeepthing's Avatar
What are you talking about I am running a 3" drop on AGX's and have yet to have a problem after 1 1/2 years running them about 60,000km put on them like this. Still ride like the day I bought them. Also warrenty will not be voided since I retail them and have never had a problem with warrenty claims.
Old Jan 3, 2006 | 12:24 PM
EJ2-Fluffy's Avatar
Default Re: Koni Yellow Shocks ?? (rbjeepthing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rbjeepthing &raquo;</TD></TR><TR><TD CLASS="quote">
What are you talking about I am running a 3" drop on AGX's and have yet to have a problem after 1 1/2 years running them about 60,000km put on them like this. Still ride like the day I bought them. Also warrenty will not be voided since I retail them and have never had a problem with warrenty claims.</TD></TR></TABLE>
It says straight ont he KYB AGX warranty papers that they will void it after a 1.5" drop. It says the same thing for the Koni Sport Yellows (SP3 and non SP3 models) as well.
When I used to have my CRX, I bottomed them out with my GC coilovers all the time. They do take alot of punishment but there is a limit as stated above.
What is nice about the KONI shocks is that they can be rebuilt here in the US with any adjustment you would like. The GC's also have the option of using any rate of Eibach spring needed.
However, even with a full 3" drop like you wanted Rob. The problem is that the Upper Control Arm will hit the chassis due to the physical location of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RaCk &raquo;</TD></TR><TR><TD CLASS="quote">My old koni'es blew gaskets all the time. With a 30mm drop. I hate koni'es.
You need to learn how to rock Koni setups properly. Nub.
-Jon
Old Jan 3, 2006 | 05:57 PM
Rob.'s Avatar
rbjeepthing, maybe you dont even know what a blown shock feels like ? LOL
AGX's are easily "blowable" after 2" drop. lol
Old Jan 4, 2006 | 07:00 AM
evil_ryu's Avatar
so whats sum good shocks to rock with theses spring springs???
Modified by evil_ryu at 2:59 PM 1/4/2006
Old Jan 4, 2006 | 02:23 PM
Riceburner247's Avatar
Default Re: (evil_ryu)
I'm running the Sprint Extreme springs on my EF. I have stock struts that haven't blown yet, amazingly. Anyways, my point is that if I hit a big enough bump, my upper control arms hit before my struts bottom out. If that is your case, then that is as low as you will go. Unless you decide to cut holes for your arms to come through....
Old Jan 4, 2006 | 02:25 PM
model x's Avatar
I'm running agx's on the front of my car with over 2" drop for a year now and a friend of mine is running agx's with over 2" of drop for about 3years. Both of us road race and solo2 events; no problems. LOL
Koni's are built better and will handle a stiffer spring rate. I don't think either brand is shortened though.
taimysho0
Suspension & Brakes
Aug 18, 2008 11:45 AM
taimysho0
Aug 17, 2008 06:43 PM
taylor1
Jul 17, 2008 07:24 AM
redDAinteg
Oct 14, 2005 08:10 PM
EricMichael
Jan 11, 2004 11:24 AM
