motor debate
ok i know this is the all time asked ?, i have a 92 si and 93 si blown motor both have the h23 i want to make a killer motor hp wise, but dont know what motor to build i would like to hit 400hp + with turbo someone tell me the best motor to get me there cause i already have a h23 laying here
in my opinion i would say use the h22a vtec get a head gasket AEM ems. and a t4 turbo with some injectors and a fuel pump tuned you should be puttin out more then that what your lookin for. if that helps at all.
???? NO. !!!!!
Keep the h23 and boost the **** out of it. Precisionh23a has/had a killer h23 boosted. You can do some crazy things with that motor - vtec isn't everything. Just remember, when boosting, you can keep whatever motor you want - as long as you build it right, the sky is the limit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dougs96SI »</TD></TR><TR><TD CLASS="quote">Since you have two blown Si's send one block off to be sleeved and use the other as a temporary piece.</TD></TR></TABLE>
What he said. Good sleeves and strong pistons (and connecting rods, reinforced crank, etc) and you can boost that thing to 400whp
xxredpreludesixx
40
May 17, 2005 07:12 PM
