Type Ones In Stock!!!!
Check them out, guys. Here is what you are looking at:
2 DC
2 EG6
1 EK Coupe
Pricing:
$675 for complete setup
$375 for B Pipe
$350 for Rear Section
Figure shipping to be about $18-22 per (full setup is abot $30) depending on location. Thanks.
[Modified by FAST4DR, 6:04 PM 3/19/2002]
[Modified by FAST4DR, 5:16 PM 3/20/2002]
2 DC
2 EG6
1 EK Coupe
Pricing:
$375 for B Pipe
can you describe besides the type 1 which type of muffler is it and also for the ek whats the price ? and would there be any problems with the rear over the axle piping since im running st sway bar on an EK hb.
how much for the seat?
No B18C5 headers?
I've got a Spoon header on order but I'm glad it's coming late. Gives me time to dyno my TypeOne b-pipe/5Zigen Fireball combo.
This gotta be real loud.. it's N1 type....
headers in yet, Dave?
Will,
= 2.15", I think someone said that was the muffler end.
https://honda-tech.com/zerothread?id=143283
How can one call that 2.5" b-pipe if the inlet is only 2.15"?
I mean 2.5" inner diameter test pipe or cat going into a 2.15" inlet can't be good, right? I remember SMSP stated that for exhaust, small - big is better than big - small?
That can't be the muffler end. The flange looks like it bolts to the cat to me. Correct me if I'm wrong, but I've never seen a honda exhaust have a 3-bolt flange on the axle-back end. And the TypeOne axle-back is the standard 2-bolt flange also, which means it aint bolting to that flange!
BTW, it's 63mm OD = 2.48" OD, which if 16-gauge steel is used, is 2.415" ID.
I think the picture that sackdz posted was from some that AJ PwR posted a while back. I saw another one where the tubing OD was 63.5mm or 2.50". Guys please remember that exhaust systems are made from tubing and not pipe and tubing is measured/spec via the OD and a wall thickness. I think the tubing used for the Type One is 63.5mm and 1.5mm wall, AJ PwR can verify these values.
The aftermarket systems that I've seen of course use a 3 bolt flange for the B pipe inlet since it has to bolt to the cat. The axle back portion always uses a 2 bolt flange so that it will bolt up to the stock B pipe (tube). The only other flange used in these systems is the one after the resonator in the tunnel, again everyone I've seen is a 2 bolt (we all know how much fun 3 bolt flanges are in the tunnel). From the pictures it looks like this system also has a 2 bolt flange after the resonator. Dave (FAST4DR) can confirm this.
Now anyone who buys/installs a 2-1/2" cat will have a 2.50" ID outlet on the cat since these cats start life as an universal cat which have both a 2.50" ID inlet and outlet. This is so the muffler shops can easily insert tubes in both ends without having to expand anything.
SMSP - Who thinks Honda-Tech would score big points with it's members if it had a components section with pictures and specs in order to compare parts without having to use the search and start repetitive threads that use precious band width.
